โœ… 9/12 Lightning Build Week Group
I Can see my BCE modules populated Blend date 9/14. What happens after this?
You will see then "IN PRODUCTION" date soon, then 10-14 days after that the BUILT date depending on chip supply and spray-in-liner application if you order it.
PV2EV
Nothing for me yet. I am 341 of 771, what was your place in line?
PV2EV
How do I see my place in line?
In the top right corner of the window sticker I have 117/581
Yeah, that is it, but the 9/12 week had 771 total, not 581, which is weird. May be due to you getting the factory bed liner, if that is correct?
So with the same blend date (9/14) and you being 224 ahead of me (which seems like a lot for a single day), I should be seeing some modules populated Monday, hopefully.
Thanks for the info.
MuradS
Murad
United States
Yes, I ordered the factory bedliner. I was wave 4, I placed my order in Feb for an XLT SR then changed it to XLT ER, then changed it again to LARIAT ER with max tow, so my order date ended up being on 4/22. I don't know if this makes a difference.
PV2EV
Yes, I order the factory bedliner. I was wave 4, I placed my order in Feb for an XLT SR then changed it to XLT ER, then changed it again to LARIAT ER with max tow, so my order date ended up being on 4/22. I don't know if this makes a difference.
Bedliner explains the 581 vs 771. I think your 117 vs my 341 is still relative though.
I hope getting the modules populated means you will not be on chip hold, and are heading towards a built date, but not sure.
greenne
Nathan
Niskayuna, NY
Fwiw I ordered the spray bedliner and I see 771 on my sticker.
PV2EV
Ford F-150 Lightning โœ… 9/12 Lightning Build Week Group 1663456280282
That was your original number, then you got sequenced after the initial run
Okay, I give up ?โ€โ™‚ , ?
It's all mashed up after the sequencing change, I follow is SQ 2 and the blend days, that's where the production ordering remains consistent regardless of SQ1 & SQ3 getting changed in the bed liner trucks.
Ford F-150 Lightning โœ… 9/12 Lightning Build Week Group 1663456435289
MuradS
Murad
United States
I already see in production date of 9/16 - I am hoping things move fast from here and I get the truck within a month
Ford F-150 Lightning โœ… 9/12 Lightning Build Week Group Screenshot 2022-09-17
Ford F-150 Lightning โœ… 9/12 Lightning Build Week Group 1663549415583
Ford F-150 Lightning โœ… 9/12 Lightning Build Week Group 1663549438270
PV2EV
1154 BCE module entries popped this morning! Still no "In Production" or "Built" date. Does this mean I will miss a chip hold?
No, there could still be be other parts which are chip related but do not restrict programming of the trucks systems as a whole.
MuradS
Murad
United States
Hi All,
I see the Tear Tag populated - I read somewhere in the forum that this is the last step.
Does that mean the truck is built?
