What's this 'mechanism' in front of the rear wheels...
it mounts to the frame, and to the sway Arm... looks like a hydraulic 'lift' of sorts... with maybe an electrical connection behind it...
Ford F-150 Lightning What's this 'mechanism' in front of the rear wheels... SUSPENSION arm small lift mechanism.JPG
...a look aft of the rear wheel, over the sway arm, forward toward the device...
Ford F-150 Lightning What's this 'mechanism' in front of the rear wheels... IMG_4919
lancersrock
Kody
USA - IA
2021 Honda Pilot, 2011 Mustang GT, 2013 fusion se
Field Engineer
Do you have the scales? I’ve never seen how they work but if this would seem to be the easiest way to just measure pressure in the bed. This assumes it’s only on the rear.
I found ones mounted to the front wheels, too... maybe this is a sensor connection for the AWD or TRACTION control or LOCKING DIFFERENTIAL.... interesting...
Ford F-150 Lightning What's this 'mechanism' in front of the rear wheels... SUSPENSION arm device FRONT wheels.JPG
Sensor for the grade angle display?
Gimme_my_MME
those are all good, educated guesses : )
LightningShow
MA
'22 Lariat ER
Product Development
Yeah, displacement sensor makes sense. There are probably a number of things that the truck's computer can use that data for monitoring/calculating.
My Pro didn’t auto level after my leveling kit. Do the higher trims have different headlights?
I'm not aware of different headlights, but with you lifting the front up, did you change the height of the rear?
MM in SouthTX
2025 Lariat PowerBoost with 7.2kW ProPower
That's how the scales and smart hitch and all those cool features work. The suspension system is a known constant (k) and these measure system displacement (x). So using F = -k*x you can know the force or mass at each corner.
Watch your language! ;)
Saul Goodman
Saul
Omaha
Formerly Mach-E FE, 2022 F150L Lariat in transit
Sandy will tell us all shortly. Then he’ll tell us why it is in too many pieces with too many fasteners.
