Departure and comfort not working
XLT Jeffy
Vancouver, BC
2022 Ford Lightning XLT SR
I would think that 'pre conditioning' has nothing to do with whether the vehicle is plugged in or not... pre conditioning is to turn on either heat or air conditioning, etc., to get it ready for you to use, comfortably, but not so much for the 'battery' conditioning... and should work just the same to 'pre condition' the cab for when you leave work, etc., when the truck would not be plugged in.
I think Tesla uses 'pre-conditioning' for the BATTERY when it knows you are close to arriving at a SUPERCHARGER, for better battery charging... which might be confused with 'cab' pre conditioning.
From the owners manual.
Ford F-150 Lightning Departure and comfort not working Screenshot_20221012_095807
Ken
Ken
Monterey
Lightning Lariat ER
noticed this morning that the steering wheel heat doesn't activate even though the light is on. The seats were nice and warm, but the wheel was not. It does work if you manually activate it, so there's certainly an issue there. First world problems.
While setting up departure times make sure you selected cool, medium or warm features, if that doesn't work try, going to settings, remote start, adjust these selections to on and auto. & 15 minutes, maybe remote start and departure use same settings.
Ford F-150 Lightning Departure and comfort not working 20221027_093401
Ford F-150 Lightning Departure and comfort not working 20221027_093417
Ford F-150 Lightning Departure and comfort not working 20221027_093432
RainorshinePNW
Anyone else having issues with their Departure Time periodically not working? I set mine up last week, and this morning (and I think one other day) I came out to drive and the truck had not done any pre-conditioning. Double checked my settings in truck and they were correct, but it just didn't do it. Will continue monitoring but thought I'd check here too. Thanks
sotek2345
Engineering Manager
Were you plugged in?
idahospud
Idaho
2022 F150 Lighting, Indian Roadmaster
Commercial Real Estate
Is the truck plugged in, I think it needs to be for that?
There is a setting that allows pre-conditioning even if the truck is not plugged in. I use it every day.
sotek2345
Engineering Manager
Can you point me to that setting? Mine was unplugged this morning and I was surprised it didn't warm the cabin. Maybe I missed that!
OB121
Bay Shore
2021 Bronco Outerbanks Sasquatch, 2019 Expedition
Thank you, yes I see that and will use it now that its getting cold. Is it defrosting the windshield?
Lime Green
CO / AZ
F-350, Expedition Max, Tesla...
Good thing too. Preconditioning in cold weather definitely helps efficiency -- at least that has been our experience with Tesla. Simply driving off with a cold battery impacts range more than anything else. So being able to pre-condition when not plugged in is huge.
idahospud
Idaho
On phone app. under "charge settings" See below...
Ford F-150 Lightning Departure and comfort not working 1667935519820
There might be a rules conflict that we can't detect, might have occurred in the midst of the recent power-ups. I deleted the pre-conditioning requirements in both the app and truck, then re-input my specifications while in the truck. Then let those settings sync to the mothership, and then refreshed to the app and tweaked the rule about allowing to precondition while unplugged.
RainorshinePNW
Definitely no power-up last night, and I'm not sure what rule would conflict with a Tuesday morning. But I get your point (thanks) that there's all kinds of possibilities particularly within software that could have caused a conflict or error that prevented the start up this morning. Will keep watching, bur reliability of this feature is increasingly important as we head into winter.
Shigoku
Austin
Tumwater, WA
2020 F-150 Lariat, 2022 Lighting Lariat ER
Shellfish
I still have days without heating for no reason. Seems to work about 90% of the time. Undoubtedly a software issue with app or Sync.
