Anyone figured out how to turn off the frunk beeping yet?
Has anybody that removed it checked for a new DTC using an OBDII reader or Forscan? While it may not throw a dash code, might still set a DTC (not that is necessarily an issue).
Looks like a variation of this part (Densco MX068900) has been used in Honda and Subaru keyless entry alerts for many years.
GoodSam
Good
occupying space
I am more annoyed by the loud pop of the Frunk opening than the warning beeper. Must be a way to make that a softer opening.
Simsonic
Sebastian
San Diego
2022 Lightning Lariat
Besides doing these mods physically (the frunk, tailgate) couldn't this be a software update in the future to disable them?
HaroldCal
Harold
Las Vegas, NV
It entirely depends on how ford integrated it into the system.
We've been spoiled by Tesla's "everything is on the network and designed from the very beginning to be software controlled ".
The Lightning was designed to use as much existing components as possible, which very likely means that many parts are just traditional dumb appendages, that don't touch software at all.
MM in SouthTX
2022 Lightning Lariat ER
I don’t have a picture of mine. It is zip stripped to the wiring harness and labeled. Thank you for the tutorial @WillB17 . It took me about an hour, but I think I could do it in 20 minutes the second time. That’s the way these things go. Ordering your backup silencer.
Photon
Oklahoma
2022 Model S Plaid, 2018 Ford Raptor
In case anyone else is running into this issue. My frunk wouldn’t close after the install, but figures out I had to manually close the frunk and then it would latch when it’s closed. The frunk worked perfectly after that.
The only thing I can imagine is that when harness was disconnected on frunk tub the frunk module resets and defaults to think it’s closed position when you reconnect power. But just manually close it and it will work fine afterwards.
LightningShow
LightningShow
MA
'22 Lariat ER
Product Development
THANK THE LORD BABY JESUS!!!
DucMan
Scott
‘22 Lightning Lariat ER
I imagine someone at Ford at ford won a bet on how long it would take the pesky owners to figure this out. A bottle of good scotch, no doubt.
DrNurse
2010 ford raptor, 2022 ford lightning
The tailgate doesn't beep on the Pro or base XLT that's a perk if you ask me. I'm tearing the Front apart to find the damn speaker for the opening/closing sound. I already have a print file for the under 25 mpg driving noise speaker to reduce but not eliminate the noise.
where did you get that print file?/could you share it?
WillB17
Will
2021 F-150 Lariat Powerboost
Glad everyone is able to perform the mod and that it's helped so many of you! Thank you again for all of your kind words and support.
Nice video! Would be nice if Megaohm got some recognition in the description ;)
