MadLighting
STephen
Raligh,NC
XLT Lighting
Anyone having issues with FDRS I added my license then it goes to a white screen saying login. and just sits there
I uses the software before on my 2022 Mach E . so i know how to use the software.. once I add the license and tell it to login with non-ford account it launches a white screen says login top right.. and does nothing
Mike G
N. AL, USA
I have no problems....you've updated to the latest version I assume?
MadLighting
STephen
Raligh,NC
XLT Lighting
There had and outtage I just tried again working perfectly
Carplay full screen looks awesome on the 12" screen
Mike G
N. AL, USA
I finally did end up experiencing the blank login page (for the last three days) and now this morning it's all back to normal again.
ytwytw
Toronto, Canada
2023 F150 Lighting ER Lariat
How can I connect the battery charger?
I saw the op said don't connect to the negative directly to the battery negative.
But I can't find where to connect the negative as the charger positive and negative cable can't be too far each other...
Does the jump post can be used for charging the 12v?
Mike G
N. AL, USA
Yes.
That right panel comes off using the plastic turnlocks.
Ford F-150 Lightning ECU module programming guide using FDRS Frunk_PL6100
Ford F-150 Lightning ECU module programming guide using FDRS Lightning_Jump_Connections
Mike G
N. AL, USA
Can the police enhanced speed mode be enabled ?
Where are you seeing this? Obviously the 15.5" screen but what menus did you get into?
Looks like someone has turned some of the Police vehicle settings on with Forscan.
ChrisCon
The Hamptons, NY
Bezel Diagnostics. turn the radio to AM or FM press and hold volume down and arrow seek left at the same time and this iis in the APM management screen I think.. I'll find it when I get back home.
@GDN I don't have Forscan or FDRS which is why I'm asking here. I just found this and some other interesting stuff in the bezel diagnostics and figured I'd ask.
Gotcha - so that makes sense if you are in diagnostics somewhere. All Ford trucks - ICE and the Lightning's have Police modes. I'm not sure what it takes to activate (I think Forscan will do it), but you are seeing some of the diagnostics that would go along with that. In Police mode you can get an all lights out mode, etc.
ytwytw
Toronto, Canada
The all lights out is an interesting feature.
It would be very useful when I need to run pro power on campground or at home.
This is a huge miss on Ford's part already. Running Pro Power should not require the truck nor any lights to be on.
