- First Name
- Greg
- Feb 15, 2022
- Dallas, TX
- Lightning Lariat ER, Performance Y
- Occupation
- IT
Do you have any other 240 v appliances ? Wouldn't that be called a brown out and cause damage to something like an AC (which you are likely not using at this point in the year)?I gave this technique a shot tonight, but ran into a problem.
The the A phase feeder from the pole transformer to the crib lines failed 10 minutes before I was expecting to pause the charging session and let the scheduled update kick off.
I noticed that my Emporia Vue2 monitor stopped reporting from the 100 amp circuit in the garage, then noticed that the truck reported charging had stopped.
Went out to the garage to investigate, using a DVM, I found that only B phase was providing 120v to the load center, the A phase had ~18 volts, looked around the neighborhood, noted the street light on the pole was also out, and several house were out completely, interestingly our house is also powered by the same transformer, but we did not lose any power to the house.
National Grid had a truck out quickly to investigate and repair the damaged wire after pulling out the 7kv fuse to the can, he spent about 20 minute replacing the suspect line and checking all adjacent taps, this can feeds 18 residences and my garage. All finished he reconnected the fuse, and we had full power.
Now, I'll have to retry the process Thursday and see if it works for me.
