Absolute proof it’s an Onboard System issue -- modem not FordPass
Daniel
Tallahassee, FL
2023 Ford Lightning Antimatter Blue with bed liner
Law
I knew it was the modem or related system, but I’ve been on a trip, and can now prove it. My modem crapped out on March 10, 2023. Typical, nothing special. any of use in the build period from early November to mid/late December experience this all the time. We all know the remedy, battery cable or fuse 32. This time I decided not to do the fix, not really for this test, this just came to be known by accident. My plan was to drop off at dealer after the trip (I’m still on it) and start the clock. What is interesting and proves the point are my images that follow. I received a notification on top right, which shows a message from Ford. Clicking through the links, which I share, you can see that my account received information of a charge (using the Ford App, not EA) and reporting the charge event to and through the FordPass App. Which means the App itself is not broken. It does communicate. The broken part is that truck itself isn’t communicating. But more importantly it is not communicating through the modem only. CarPlay works, Bluetooth works, satellite works. So the loop in the example below is that (1) I connected the truck to an EA station and the truck exchanged proper protocols (not modem) and then (2) EA station connected to FordPass App (Wi-Fi) and FordPass/my credit card but I’m still on free volts. The truck never communicates via the modem at this point, it knows only what is provided through the direct connect to the station such as connected/disconnected and charging. Unfortunately very little detail is displayed in the actual truck. EA station has more detail, such as energy delivery amounts and rate. What is interesting is that although my FordPass App has no idea anything has happened in the last 4 days, including charging from the truck, it is aware directly from Ford that I have been charging. Ultimately, meaning the FordPass App works but only can process or display information from which it receives. In this case, since the truck can’t share the information it has, it cannot be shown in the App. That is where the loop breaks in my case study.
On a side note, all data, or lack of it is shared to Ford, it’s in the truck setting tab, unless deactivated. Meaning Ford most be aware of the issue, or must be aware that about 2000 trucks (approximate amount during build period) are not sending data to Ford. In either case they would know something is odd, and would have discovered everything I just shared a long time ago. Considering they are not disclosing and pretty certain the have instructions to not discuss the issue on 10%-20% of the built vehicles means they cannot find a fix. Otherwise, they would just say that the modems are bad, and that they are working on a software solution before going to a replace scenario. By the way, I’m not saying that is the wrong approach, the strategy is sound and frankly, under the circumstances…reasonable. I just wish they would be honest, because they probably already polled a sample and know we are not all going to rush to return our trucks after all the wait. Oh to be safe, these are my personal opinions based on my personal experience.
Ford F-150 Lightning Absolute proof it’s an Onboard System issue -- modem not FordPass 46C4710A-EA4C-40D3-9D3A-AEE962F1E456
Ford F-150 Lightning Absolute proof it’s an Onboard System issue -- modem not FordPass BA51DC68-93E5-479A-8786-995D139955C5
Ford F-150 Lightning Absolute proof it’s an Onboard System issue -- modem not FordPass 80349580-1EA4-49E5-B8A0-44D31065501E
Ford F-150 Lightning Absolute proof it’s an Onboard System issue -- modem not FordPass 2756E9B3-7EEA-47DD-88CC-9D7F1C9684B8
Coolbreeze704
Troutman NC
2024 F150 Flash - 2024 Tesla Model Y LR
Thanks for taking the time to share. Very helpful and makes sense.
"Otherwise, they would just say that the modems are bad, and that they are working on a software solution before going to a replace scenario."
Nope. They never discuss ANYTHING.
BennyTheBeaver
Yes, it is 100% a hardware (firmware) issue (modem/gateway) with the module. Yes, a fix is on the way. No, the current TSB won't fix it.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
I had a similar experience. I was returning from a trip on a Sunday and on Monday I checked to be sure it had charged overnight. FordPass still showed my truck at my brother’s house about 80 miles away. I decided to leave it disconnected and I scheduled service with the dealer. On Thursday I got a notice on FordPass that it had finished charging. I looked and it showed me at the EA charger I stopped at Sunday night. I got a few more notifications and then it showed me at the correct home location. That’s the first time that it has recovered on its own. Those messages were stuck somewhere all week, I assume queued up in the truck. I wonder if there is something about certain messages that hang the modem and after some period of time old messages get deleted allowing the communication to resume.
lancersrock
Kody
USA - IA
2021 Honda Pilot, 2011 Mustang GT, 2013 fusion se
Field Engineer
Mine recovered over the weekend on its own as well and then today after dropping kids off it updated to 4.2.1 off schedule so who knows
Arrington.LCA
Luke
Colorado
I've experienced the same delayed notice about using my EA credit. My actual usage was back in December while I was waiting to receive my charger, and a week ago got notice of the reduction in my EA credit. My balance was already correct, but had never gotten the "receipt" notification.
My modem is like many with a December build, just goes a few days working then stops and do the battery reset. Very annoyed since it messes with my EV driving logs and charge logs information. Really hope this is fixed in the next couple months. Rest of the truck is great, but I use app all the time so it is frequently annoying to see it not working.
MillieChliette
I know it's only semi-related but the scheduled updates are only for the ones that make the vehicle undrivable. It installs the other ones whenever.
TallyLightning
Daniel
Tallahassee, FL
Law
Yeah, my post was to share what may be the likely culprit. I love the truck, just want truth and transparency. I wonder, is there a way to create a poll?
As the OP of this thread, you should have an option to add a poll, if not I can add it.
Let me know in a PM if you need help and what you want the poll to ask and what options.
Ford F-150 Lightning Absolute proof it’s an Onboard System issue -- modem not FordPass 1678831495696
BennyTheBeaver
The modem is the culprit, the fix is the 4.2.1 update alot of us are receiving today.
lancersrock
Kody
USA - IA
Field Engineer
thats seriously helpful.
NCevGuyF150
North Carolina
22 Ford lightning
Repair technician
I just picked up a brand new 24 lightning today. Has 100 miles on it. And the modem is not working. They said I have to take it back to the dealer.
clippy
Southern California
‘24 Mach E Premium, '24 F150 Lightning Flash
I just got a 24 lightning flash last week and the modem is not working at all.
Dealer said to call Ford after having it for a week.
Ford phone reps ref. a TSB and to call back to check on the status.
Did you ever get your modem working? (If yes - how)
tearitupsports
Russell
Cypress, TX
What do the icons on the top right of your center screen show? Assuming you have wifi turned on, when the truck is stopped you should have the Wifi symbol, and the up/down arrow icon.
If the truck is moving then you will have cellular bars where the wifi icon was. They switch back and forth depending on if you are moving or stopped. If this happens then it is probably working.
When the modem craps out (and it can change from trip to trip or even happen in the middle of the drive) the cellular symbol never goes away even when stopped. Also many times the up/down arrows won't appear either.
Usually it will never fix itself during a drive. If you are able to turn the truck off for at least 10-15 minutes and then re-start it then often it will resolve itself. Sometimes it takes a few drives to come back.
Things that are nearly assured to cause issues are:
starting the truck and immediately putting it into reverse before the system has a chance to fully come online. Unfortunately this is my normal routine.
using the built in Alexa app.
long level 2 charging session. Not much I can do about this.
