GarageMahal
JT
Data Wrangler
Texas Dan
Daniel
No Lightning's listed. Fusion PHEV & Mach-E, listed, but NO Lightnings
This was discussed extensively in the previous thread and on the website. The modern factory manuals are taylor made. You enter the VIN and you get a taylor made manual.
So YES the Lightning is available on the factory-manuals.com website, that’s where I bought mine.
GoodSam
Good
occupying space
Ford F-150 Lightning Rear motor replacement pic 1731092503743-
RickKeen
Rick
F150L SR Pro
sw engineering manager,
The fluid in the differential/final drive is going to age less than the diff/axle in a conventional vehicle. With an active pump and filter, its going to stay clean for a long, long time. With clean fluid, the gears and bearings are going to last nearly forever as well.
My prediction is that the seals or the pump will generally be the first things to fail.
I agree with the poster who mentioned that if you ever do swap the oil, it will; be way less work to just suck it out with an extractor from the fill hole and the port where the filter connects.
Rlevans
Russ
Asotin WA
2023 Lariat F-150 Lightning
Well, just spoke with service advisor and its looking good.
He says they have been test driving it and 1 pedal works and codes are gone.
Cautiously optimistic for now.
I'll post the codes and info when I get it.
NCevGuyF150
North Carolina
22 Ford lightning
Repair technician
Thought I’d post a pic of rear motor out of the truck. I couldn’t find any posts of this having been done before.
Rear motor is being replaced in attempt to fix my 1 pedal drive fault.
Apparently the module in question doesn’t come separate and the entire assembly gets replaced. ??
Question, what does that filter do?
Seems like creating an awful lot of junk for the price of a module.
Collects metallic fragments generated by the differential gears.
Thank you, at what point do we need to replace the filter and add more oil or fluid?
It's never stated in the owners manual or service guide, but I'm planning to request the technician change it at 150K
Rlevans
Russ
Asotin WA
Well, truck is not fixed.
Rear motor replacement did nothing but waste a reportedly 8k part.
Codes are back and 1 pedal is still non-op.
I’m at my wits end with this thing.
StevenC56
Steven
Fresno California
2024 Lightning Lariat Avalanche, 2017 Explorer Platinum
Bummer. This is the problem with issues of this nature. Newer tech, poor training and techs that are less than worthy. Most techs these days are flat rate and just not willing to invest diagnostic time that they probably won't get paid for. So they blame the most expensive component and become parts replacers which results in this unfortunate situation more often than not.
Taddio
Tad
State College PA
2023 Ford F-150 Lightning XLT Standard Battery
Application Developer/Engineer
I bought an ostensibly factory service manual from https://www.factory-manuals.com/
I was a little dubious at first, but after reading through parts of it, I think it is legit. I have used it for a couple of things already. It was about $130. I am a hands-on engineer type and I really like having a manual.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Wow, sorry. I assume you took it to Lewiston? They too must be frustrated. I just reviewed your previous posts, sure seems to be a software issue, perhaps after that update.
Perhaps a dealer in the Tri-Cities?
tubby
Press
Iowa
I just lightly scanned this thread, but I'm assuming they tried a software reinstall or fix? I would think there would be a sensor somewhere too which I'm sure they checked.
