When I read this it made me remember I did some testing with Ford and the Home Intergration Kit. They had me go into a diagnostic sync menu and enable an Advanced Analytics Token.
I wonder if I still have that setting on and if the presence of that token is the cause of this "issue"
I made a post on the undocumeted Diagnostics menu. I wonder if this is the same place you enabled the token. Under Testing Settings there are several possibilities. If so, maybe you can turn it off if no longer being used.
Mike G
Mike G
N. AL, USA
Yeah if you’re no longer doing the testing that requires the tokens they apparently will keep you from updating. That’s no bueno.
I did shutdown multiple times, reset the test, and even unhooked the negative 12V terminal for a little while
I wasn't on the forums much the past two days, but it seems like you were able to get everything done?
Jasin
Jasin
2022 Lightning ER Lariat
Got nothing done...brought the truck in about the 3x errors. I know now they are due to the analytics ticket
I am now fighting them to fix the 360 camera they still claim there is nothing wrong even though I showed them the exact fix and compared it to a MY 24 on the lot
jlcreasy
2023 Lightning Lariat
So I didn’t IPMA and PCM updates and seem to have broke 1-Pedal driving. Also, is there Forscan changes needed to enable BC1.4?
PJnc284
Garner, NC
For 1 pedal, check the below in FORScan for the APIM. If the value you have is PD Enabled, try changing it to 0 or another value, write and then revert it back to the previous value. Someone else had a similar issue after the dealer updated theirs.
Ford F-150 Lightning Lightning Software Updates using FDRS 1734117171208-r
Jasin
Jasin
I disabled the tokens. Headed home now. Dealership is worthless 360 view still not fixed even after trekking then the exact thing to do.
Going to hook everything back up and hopefully get what I need do everything before my license expires
Well, I checked the VIN you sent me and it seems every update is done except for the RFA (which can be a PITA) and the TRM. The truck is pretty much fully updated.
Yes, message me.
I sent you a DM.
Ok, so the dealer did it.....got it. The did the rear camera and pro trailer alignment, but not the 360 camera alignment. I would do the 360 alignment as well as the IPMA calibration procedure. The 360 cams one will require you being in an empty parking lot with marked parking spaces to do, and the IPMA calibration will require you driving the truck a few miles while plugged into the laptop on a street will well painted lane markings.
Jasin
Jasin
So I attempting the 360 camera fix and I am getting this
The bottom one is what I am seeing right now
Ford F-150 Lightning Lightning Software Updates using FDRS 20241213_153826
Ford F-150 Lightning Lightning Software Updates using FDRS 20241213_155741
Wait, what is it you are trying to accomplish here? Are you trying to get 360 view to be larger on the screen?
Jasin
Jasin
Yes. It is suppose to be fuller like it was prior to the 24b56.
I just did the FORScan fix under 7D0-01-04
It is fixed.
I think I am 100% except BC 1.4
It is fixed.
I'll message you.
