ditkafan1985
NOVA
2023 F-150 Lightning Platinum
IPMA update failed twice on my 23 Lightning. Trying a third time. Fingers crossed.
Mike G
Mike G
N. AL, USA
Download link to the new FDRS 43.6.3
Ford F-150 Lightning Lightning Software Updates using FDRS FDRS_43-6-3_Now_Availabl
On all major releases like this one, remember to tick the box to 'remove user data' during setup, or you might end up with some strange results the next time you try to use the program.
ditkafan1985
NOVA
Third time trying ipma i got all the way through but got this error at the very end. Please advise.
Ford F-150 Lightning Lightning Software Updates using FDRS IMG_4986
Mike G
Mike G
N. AL, USA
Reconnect and run the IPMA Configuration tool. See if that helps.
Ford F-150 Lightning Lightning Software Updates using FDRS IPMA_Config_tool
ditkafan1985
NOVA
If that ran successfully am I good? It only took about 60 seconds and I didn’t get any errors so I’m assuming it worked.
Mike G
Mike G
N. AL, USA
Mike G
Mike G
N. AL, USA
Is there still an IPMA and PSCM in your available list?
ditkafan1985
NOVA
After running the IPMA Configuration tool, and the test, I tried re-running PCM even thought it said it completed successfully and it cleared the last error.
Mike G
Mike G
N. AL, USA
Very good. So...all caught up now?
ditkafan1985
NOVA
Ran RFA twice, both times its completed successfully, but it doesn't want to clear and stays in my software update list. Also BCM is there as we can't do that one anymore. Otherwise, I believe I am all caught up.
Based on discussion on the other thread, I've placed this one in sticky status.
Leaving the old one as a sticky for the moment until you all agree if it should be closed.
Mike G
Mike G
N. AL, USA
Just noticed this morning that I had a new gateway update available (which is always welcome as it normally leads to other things getting updated). It could have shown up in the last few days, but I only checked this morning so....
I like USB-based updates...don't need to drag out the PL6100 :cool:
Still got the 'ususal suspects' (ACM, RFA) on the list as well....
Ford F-150 Lightning Lightning Software Updates using FDRS Lightning-GWM-Update-12-Feb-25
