awilli1010
SE Michigan
Anyone come up with a fix yet or heard anything from ford?
Pitbull2o08
Ohio
2011 F150 FX4 Ecoboost
Is this something that gets updated with the mongoose?
klossfam
East Amherst, NY
2022 Lightning Lariat & 2022 Hyundai Ioniq 5 Ltd
Attached it shows the Target Charge locations came to a screeching halt after 10.3.0. Home and the 17 N Castlerock are the same position (ironically 17 is my neighbor but it has always shown that address when I'm on that side of the driveway).
Full transparency: I always charge to 85% if home and 100% if leaving on a road trip. I have VTOU rates from 11 pm-7 am so that is when we charge our vehicles. Also, I'm running a hard wired Chargepoint Home at 32A, so 7.2 kw/hr (Sold my Charge Station Pro).
Since I usually don't charge until I'm in the 15-25% range, I'm not going over 75-80% by the time I have my Chargepoint shut off at 7 am. Still, I used the Target Charge for our cottage and condo also and it was nice to not have to think about it if you didn't want to.
I'm assuming a new update or patch is coming soon to erase my AM/FM presets and turn on Brake Coach once again...
Ford F-150 Lightning OTA Software Update 10.3.0 - Powertrain, Battery, Parking Brake Screenshot_20250203_144212_FordPass
Maineiac12
Iowa
Hey, I used to live 2 miles away from you! ? Small world.
tw2023
oh
23 lariat
mgr
Nah, front sensors or not BC 1.4 isn't coming
So I had my truck in for a battery module replacement. I asked them to update to 1.4 and that was on the loaner I was driving. They said they couldn't. They had someone onsite from FORD who said they would be rolling 1.4 out in 3 phases whatever that means and they were currently in phase 1. I was told my VIN was in phase 3
Maineiac12
Iowa
Would it kill them to tell us this stuff?
klossfam
East Amherst, NY
BTW, do you think 10.3.0 contained any DC charge curve refinements? Asking because my first DC session after the OTA on an EA 350 (a 27 F day with only 10 miles of battery preconditioning) peaked at 186 kws and than sat in the 140-154 range all the way to 80% SOC. This is about 15 kws higher in all areas vs prior to 10.3.0.
luebri
Neenah, WI
I have not seen a thorough analysis of it but I've seen a few people online state the F150 Lightning used to max at 450A (180kw) but now some owners have seen the max at 500A (200kw) charging.
I have not seen whether this is limited to a certain model year or not, but it's definitely something to look at. I have typically peaked between 170-175, but have now seen a few reports of users being above 180kw. Again not sure if this is limited to certain model years or not. Since you have a 2022 it would seem to indicate it is not limited to certain Model years.
I'm 10.1.0 (not EAP), but seem to be on the update cycle right now , I might try and DCFC before the update to see. The temps here are cool so I'm guessing there shouldn't be any throttling. Previously my truck maxed at 167kw with a sustained 123kw, so it will be interesting to see where I am at now.
Guess I need to let the SOC drop some.
Frankly, if Ford snuck in a DCFC speed increase and DIDN'T tell anyone that is a HUGE fail.
luebri
Neenah, WI
See post 131. ?
Thanks for testing, yes report back please.
