I think Utter will still do mobile service. But when I called Five Star Lewisville, they said they no longer do mobile service for software updates. They had too many issues. Morons don't realize the issue is likely the tech not connecting a power supply. They offered the pickup/drop-off service instead so I did that. I had them do the three CSPs I had at the time. They were pretty quick and did all the updates.
Yeah - new scheduler/service advisor at Utter - Tiffany I think it was, just told me I was too far away for them now. Tracy at 5 Star did check with a tech, I think they knew agreed they needed to get power supply, but they started down the road of they knew it would take all day.
So I'm choosing the least of my evils. I think at least at Utter I'll call the guy that has helped me a couple of times and let him set it up for me.
Mike G
Mike G
N. AL, USA
Well there’s all of those considerations plus the fact that Ford still hasn’t told their techs that this IPMA/PSCM script is broken, and unless you know to separately run the IPMA Configuration tool in FDRS afterwards you’ll likely end up with a partially completed update that will result in you still having a PSCM update in your available software list. This is an issue that many of us who’ve done this update have known about for what….four months now?
I still need to get this done and hesitate for the very reason that it might not get done correctly.
Think I'll put this off until late spring when I can ride the Harley they while play with the truck for x days getting it done right.
I'd love to talk directly with the EV tech and feel him out for knowledge and attention to details, unfortunately the Service advisors & Manager got them pretty well hidden and out of reach.
I had it done and ended up with the tiny 360 view. I changed it back with FORScan and just lived with the menu button to get to the camera views. When I updated to 6.14, it seems that applied/configured whatever the tech didn't as I now have the correct button layout. Don't know if it was a coincidence that the update happen to run the config or not. Point being that you could get it done, fix the view yourself, then let a future update perform the config.
Or bring a case of beer to the technician as an incentive to get'r done right the first time.
mb0220
Matt
2022 Lariat ER
Less optimal.
Mo optimal.
How did you fix it? Or did the dealer need to do it? (If so, please let me know what to tell the dealer that might expedite resolution.)
Mike G
Mike G
N. AL, USA
Well, they could start by re-reading the TSB. It says right in there what they need to do.
Step 11.
Ford F-150 Lightning CSP 24B56 - Inoperative Front Parking Sensor(s) - IPMA Software Update for Certain 2022-24 F-150 Lightning Trucks 24B56_360_Camera_View_Fix
But apparently it's 'rocket-surgery' for many of these folks....
potato
BC, Canada
2023 F150 Lightning XLT ER
Dammit. After news of the fix I made my appointment for this for the 25th. Hope they actually release a fix by then.
Mike G
Mike G
N. AL, USA
I like this game....very entertaining to watch.
Ford F-150 Lightning CSP 24B56 - Inoperative Front Parking Sensor(s) - IPMA Software Update for Certain 2022-24 F-150 Lightning Trucks IPMA_FDRS_Config_Maybe_Fixed
I <3 My Lightning
Had this completed today on my '23 XLT ER. It doesn't take as long with this system. However the tech said they had to run it 3 times because it kept kicking them off.
They also said there was something else in cue in the system but they wouldn't tell me what it was but I think they may have installed what ever it was due to some changes on how the truck now performs.
1) The main screen reset. Brake coach, calm screen, all the trips, seat belt, ECT all reappeared. All my custom main screen features had to be reset to my liking.
2) Infotainment system audio reset. Volume was set at zero, Tone settings, position, speed volume compensation all went back to defaults. The system went back to radio and defaulted back to the very first memory screen/spot. But hey at least my saved stations still remained.
3) Both screen brightness settings went back to defaults.
Now the driving characteristics...
1) The drivers assistance safety system picks up vehicles in front much faster and for much farther distances ahead. I keep the distance at 2 out of 4 bars.
2) The front camera auto switching near objects is way faster and now I will get the camera view before the sensors being set off. In the past the sensors were already beeping before the camera would even switch on.
3) When in Sport mode, the steering feel is much less resistant. It's almost like being in normal mode but with all the acceleration and Regen as in sport mode.
4) Lane assist is more on center and corrects itself twice as fast.
5) Because the steering appears to be lighter/less resistant, I can rest my hand on my thigh and lightly hold the wheel between my thumb and index and that's enough to keep the nagging at bay. BUT if a long stretch of straight road it's nagging away, probably due to its ability to be more on center.
6) Bluetooth... I think the tech's issue with the update being kicked off the 3 times was due to something that improved the Bluetooth range. While on my phone in the waiting room that is a reworked old dealership where my location is the old service bays and with my truck in the service bay a building behind, I got notifications on my phone showing it was connected, which I had then disconnected. I thought perhaps it was a fluke but turned on the Bluetooth a little while later and it reconnected. Then I just left it but then received a call and disconnected it again.
mattskr
Matt
Austin, Texas
23 Platinum Iconic Silver
Ahem....
Hmm...my truck had this done at the dealer either Feb 13 or 14 obviously while it was broken. Now I wonder if they really did it. The CSP is no longer listed in Fordpass.
Zed
Chuck
2022 Lightning Platinum Rapid Red
Not so entertaining when/if your truck is involved....
I'm taking mine back in next Monday to have the "new & Improved" programming performed. It spent 3 days at the dealer last week just as all the problems were happening with the server.
I <3 My Lightning
For all the XLT class and below with the 312A package with ACC and copilot assist 2.0, don't hesitate to get this update. I was hesitant as this thread and the Blue Cruise 1.4 thread appeared to be more geared towards those with Blue Cruise. Because we have less complexity for this update, the update is much faster and IMO I have an even more refined ride. It's like a whole new truck.
The driving experience is better after this update. I am one that actively will move away and line hug as I pass vehicles on the highway and when I first got the truck I immediately shut off lane assist because I hated having to fight the wheel. After a while I got use to it and reactivated lane assist. This update fixes the fight.
Two other major changes with lane assist and this update. City streets in my area just have the center line and nothing to the right because of the sidewalk curb. Lane assist never worked accept during a major anomaly, clear road but curb laden snow. In this case I had to do some major fighting because it thought I was not centered and being center would mean park cars, garbage cans, and drains were fair game to run into/over. Now with this update it now shows it can read the center line and ghosts the ride hand line if it doesn't exist and also ignores the curbed snow as a line.
The second thing it fixed was the jarring erratic lane centering fight that occured when using a merging or exiting ramp where the lines broke.
