Google maps not planning charging stops
P-38
2024 Lightning Lariat
Hi,
I've been struggling to get this to work.
I have a pixel 9 that pairs fine with the truck, no Android Auto issues.
Google maps loads fine and plots directions fine.
But it won't plan stops. I'm entering the destination in the Google maps on the touch screen in the truck and the truck knows the destination is too far away (orange under range remaining)
Ford navigation works fine and plans the stops.
Any suggestions of what to try?
Ford F-150 Lightning Google maps not planning charging stops 1000000328
Ford F-150 Lightning Google maps not planning charging stops 1000000329
Ford F-150 Lightning Google maps not planning charging stops 1000000330
Ford F-150 Lightning Google maps not planning charging stops 1000000331
Mashedtators
2023 Lariat ER
Route C will have a couple more tolls but will be faster unless you hit downtown Chicago at 2am
B177y
Olympic Peninsula, WA
Hi,
I think there is a Sync update that you need to receive for Google Maps to show the chargers.
You didn't have any selected on your google maps route. Try viewing gmaps in full screen and add the stops.
P-38
Not sure I understand what you mean. Yes I can add a stop to maps and those can be EV charging locations...but I was under the impression EV routing would add them automatically, where I need them and how long I need to charge like Ford navigation or ABRP.
Bryce G
Bryce
2024 F150 Lightning Flash
This is not working on my 24 Flash also, even after 10.1.1 so I think they have not pushed some part of the software udpate that enables this feature in Android Auto yet. Even though it says it requires 10.1.0 in their own help documenation... its quite confusing and frustrating.
Lee1034
Leeroy
2024 ford f150 lightning flash
I'm also on the same position my 2024 flash is on 10.1.1 and no karaoke and the google maps battery percentage.
On your phone, set up a drive and check the settings under "your vehicle"
Ford F-150 Lightning Google maps not planning charging stops Screenshot_20250314_132225_edit_2850430990487942
P-38
Ok. The truck is set up there
Ford F-150 Lightning Google maps not planning charging stops 1000000345
Pre-tariff-charge
Ben
2024 F-150 Lightning XLT
This is the point I've reached as well. Sync and gmaps software updates confirmed, truck setup in gmaps with connectors added but no EV charging stops or battery percentage. Ford support is blaming Google.
As mentioned a couple times above, your '24 Lightnings are missing one of the OTA's that fully enables the integration.
USE THE FEEDBACK utility in SYNC to blast Ford about the problem, if enough of you complain through this utility it ~might~ get someone's attention to push what's missing
mr.Magoo
2022 Lariat ER, AMB
So, speaking of Google Maps and charging stops... (mine does plan it btw)
I experienced a really annoying feature and its that if your battery is expected to be low at your destination (10% in my case) it'll include a charging stops without you asking for it.
I was picking up relatives from the airport and used the navigation to get home, because we have road construction literally everywhere (summertime in Michigan) and road closures changes daily. The navigation insisted on taking a weird route and it made no sense so in the end I turned it off, once I got onto I75 I turned it back on as a test and it insisted on charging at the fast charging station that's literally 400yards from my house/destination, despite being able to make it with 10% left.
I did not add a charge stop or hit a "please include a stop", just go home and start navigation.
I poked around in the settings and I couldn't find a "arrive with a minimum charge of X%" setting either.
For someone who has this working: Off topic slightly but under plugs and adapters, he checked Tesla. I just chose NACS (and CCS1). Will choosing Tesla give you stations that we can’t use or does Maps know those as well?
Just looking to use for trip tomorrow so haven’t tested yet
P-38
If I could get it to work...I could tell you if the check boxes change anything...
I've been leaving feedback for Ford 4 days a week for many weeks....
