Range Anxiety, What's that?
bryansocko
Bryan
2023 Lightning Platinum
Ladies and Gentleman I present to you my EREV:crazy:
I find Pennsylvania has quite a few charging deserts when towing.
If I need to go somewhere far I just simply load up the big inverter generator and 11kw portable charger.
Now if I would ever be close to running out of range I can put enough charge in her with the level 2 so I can make it to a DCFC.
Sure it's only 11kw rate but it would could be a savior.
Anyone else take the nuclear option?
Ford F-150 Lightning Range Anxiety, What's that? 20250419_214319
ryun
Earth
Noice. Gotta do what you gotta do. What kind of gas mileage are you getting? ?
Dominic
2023 Lariat ER
See everybody? EREVs are super practical. All you have to give up is the bed.
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
11kw is a good charge. Have you calculated your gas mileage? I've always wondered how efficient it is to charge using a generator.
A lot of people laugh at that, but don't think twice about carrying gas cans to fill up an ICE truck.
Duke_239
Duke
2023 F-150 Lightning
As our home electricity pricess keep climbing, ypu always have to re-calculate the cost to charge from generator. In sone parts of Massachsetts we pay 35 cent kWh delivered.
Webbo85
Marc
Glenmoore, PA
2023 F150 Lightning Lariat ER, 2023 Mach-e, 2002 Jeep Wrangler
Mech Engineer
Where are you in PA? I know the center of the state use to be bad, but I feel with the Tesla access now most issues have gone away. What's your mi/kw when towing? Just surprised this is necessary, at least in my experience.
bryansocko
Bryan
So I did some initial testing today just to see the outcome... For science of course.
It looks like I can add 2 kwh every 11 minutes in an emergency situation.
Now granted I am an Electrician and this generator is used on jobsites.
I wouldn't advise anyone to spend 5000 to haul a generator around only for piece of mind.
Ford F-150 Lightning Range Anxiety, What's that? 20250421_151656
Ford F-150 Lightning Range Anxiety, What's that? Screenshot_20250421_152010_FordPass
Wendy
Puget Sound
1967 Saab 96 (dead), Silverado (squished), 2023 F150 Lariat ER
So plug in to the generator and drive 24 miles per hour. You can go ANYWHERE!
GarageMahal
JT
Data Wrangler
Except we can't charge while driving...
Wendy
Puget Sound
Darn. I was hoping that if I got stuck a couple minutes from home my neighbor could run a cord from his bed to my truck while I followed him home. ?
Cvh8601
2023 Lightning Lariat
Also curious. I’m not towing but I’ve made a loop recently several times coming up from MD to Buffalo via US 15, then over to Fredonia NY and back down through central PA again via Jamestown NY and Warren PA.
There is definitely a charging desert in kind of Mid to NW PA in the Allegheny region, but otherwise I-80 and I-99 seem pretty well covered. Towing would be an issue between Jamestown NY and the nearest charger in PA, especially in the winter I’d suppose. No big deal for ER battery without towing though even in very cold weather.
