Air filter change and debris
timothyedwards
Tim
Canal Winchester, OH
22 Ford Lightning XLT, Nissan Leaf
Changed my filter with Pureflow hepa and noticed this when removing the old one. Not exactly sure what it is but wondered if anyone else has seen similar. It is soft.
Ford F-150 Lightning Air filter change and debris image
frautumn
Fred
Northern CA
2022 Ford F-150 Lightning Lariat
What is the process for changing the air filter, where do you access it? (yes I'm too lazy to open the manual)
jimfigler
Orchard park, NY
Looks like nest material. In a side note those Hepa filters can be more restrictive than stock and make the HVAC system work harder and less efficiently
timothyedwards
Tim
I decided I wanted a better filter than the stock one to hopefully cut down on outside smells. Up to this point the dealer has done all the services.
Athrun88
Toronto, Ontario, Canada
I recently installed a Pureflow filter. Didn't notice a huge difference in air flow but it didn't help with reducing any outdoor odours either. Happy that it's probably filtering things a bit better but disappointed in failing to reduce the odour by any noticible amount. I'll be going back to the OE filter for the next swap since it's 1/4 of the cost.
Charge_Rob
2024 F-150 Lightning Lariat
Charging Nerd
Mouse nest
B177y
Olympic Peninsula, WA
Looks like you have something living in your HVAC. You definitely want to track that down.
frautumn
Fred
Northern CA
The Motorcraft FPP-92 filter is also available, it's the enhanced MicronAir ProTect version of the stock filter with an anti-allergen coating. https://parts.ford.com/shop/en/us/f...bin-air-filter-odour-and-pollen-p-fpp92?pdp=y
Thanks for the tip. I tried to order from Ford website that you linked but it was giving errors. I found it much cheaper at RockAuto thanks to this thread: https://www.f150gen14.com/forum/threads/cabin-air-filter-motorcraft-fpp92.29191/
Order link is here: https://www.rockauto.com/en/moreinfo.php?pk=14790249&cc=0&pt=6832&jsn=2081
Bushwood CC
Pete
Ford Lightning Flash
teacher
This is the cabin air filter? I was just talking with another Lightning owner how nice it is to not have to pay for engine air filters and oil changes, etc.
Ragman
Mouse for the win! Now where that material is coming from... some traps with peanut butter in your future. I do have some nightmares about what the wiring is made of in these trucks (the soy issues of the past). Particularly a nice "warm" battery pack...
