It's enabling the lane biasing toggle. You're basically taking whatever you had as the original value and changing it to Lane Biasing Enabled, keeping everything else the same. Mine was originally an A so should be a C to add lane biasing.
I led you astray up above. Should be an E to enable Lane-biasing and keep KDA. Sorry about that.
@astrand1 Did that change fix the
Any idea what this change you had me do in the APIM does? Just curious. Also here is my VIN just in case you wanted to look at anything else.
This is what Ford shows for you:
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1746203471553-mr
So you need to change the D to an F to get cameras at speed working.
Also, this value:
x0xx xxxx xx--
That is always a 4. I am not sure what "DSMC type" is, but that is always a 4 in as far as I can remember.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1746203546915-sv
astrand1
Alex
Studio truck driver
Also, this value:
x0xx xxxx xx--
Yes. I replied that those changes brought back the bed cam at speed. Thank you.
Maineiac12
Iowa
So between last year and now, I added a note to clarify that mod is not about the light bar. Instead the mod changes the DRL's shown here. You probably should change them back to 10%. Folks found that it looks like you have your brights on all the time and other drivers will flash you.
So there is no way to change the light bar brightness?
With FORScan - not that anyone has found.
You could tint it to make it less bright.
astrand1
Alex
Studio truck driver
IPMA
706-02-02
xxxF CExx xx--
Edit: Btw, I think the changes I sent you to enable BC 1.4 a while back ago contained an error. While you're in there, check this setting in the APIM and if it is a 4, change it to an E:
7D0-09-05
xxxx xxEx xx--
So I wonder if this change for BC killed my assisted lane change? It’s still showing on in the center screen but now the truck will not change lanes when turn signal is on. I’m about to install a comma 3 so this might be moot but thought I’d share the feedback.
It shouldn't. Lane change is enabled in line 706-01-02. Message me the VIN and a screenshot of the first for lines of the ipma. No rush..... I'm not home and can't look into in until later.
LiteNing
Nic
'23 F-150 Lightning Lariat ER
1's and 0's and lambdas
Police interceptor perimeter alert
https://www.fordservicecontent.com/...A&div=f&vFilteringEnabled=False&buildtype=web
In the interceptors there is a physical button but I imagine the rest is mostly FORSCAN changes. There is mention of sensors behind the bumper but I'm going to guess those are the same sensors as our parking sensors...
This would be a neat feature, even if not all that useful for most
Interesting. This document seems to suggest that it uses the BLIS sensors: https://www.vdm.ford.com/content/da...ral/pdf/brochures/24_FordPro_Police_guide.pdf
hajalie24
2024 F-150 Lightning Lariat Antimatter Blue
The code for the seat belt chime didn't work for me...
In addition to what is listed I also did the following, thanks to /u/SNBI1791 on reddit.. now it's working.
Open IPC as built
Change line 720-13-01 and 720-13-02 to ALL zeros. Change line 720-14-01 and 720-14-02 to ALL zeros.
Then write it.
fvineyard
Frank
Roanoke, Virginia, US
2024 F150 Lightning Flash, 2023 IONIQ 5 SEL
IT Manager
Open IPC as built
Then write it.
It did not work for me either. Time to renew my license and double check my entries. I will try this if it still does not work. Be nice to not hear the chime when my Boxer rides as co-pilot.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 Canine_copilots
Open IPC as built
Then write it.
Might be a change starting with 24. I’ll take a look and update post 1.
That sure is changing a lot of values. Did you look at the spreadsheet to confirm?
hajalie24
Spreadsheet? Don't think so but maybe you can link me.
I just rolled with it and it worked, I made a backup just in case of course. That reminds me I need to backup my backup lol
hajalie24
I found the spreadsheet, yeah looks like it's different for 24' and confirmed.
Very interesting spreadsheet. Will dive deeper into it and see what else is interesting!
