Bigger front battery?
Kansan
Wayne
2024 Flash
Civil Engineer
Which battery did you get? I'm interested.
I installed the DieHard H3-xEV. The labeling indicates 420 CCA and 40 amp hour capacity. The OEM battery label indicates 380 CCA and 35 amp hour capacity.
I'm eyeballing this as my replacement, going to swap it out when the truck hits 3 years old in August.
GoodSam
Good
occupying space
Given I drive 3-4 times per week, I can go 2, sometimes 3 days without driving, and that kills the LVB over time with repeated deep discharges even when the truck is plugged in, since it won't charge the LVB unless the HVB is charging.
Can you set a departure time for every day that would bump the charging? It would waste some energy heating the HV battery pack - not sure if that would pay off. How deep are those 12Vdc battery discharges? I also thought that the updated Battery Monitoring Sensor was doing a better job of keeping the LV battery topped off, even if truck sits? Is an OBD2 bluetooth monitor draining the LV?
Remember that departure timer will only kick on two times, then require a manual start on the third day to reset the departure/remote start counter.
Adventureboy
Yes departure time might work but it seems silly to jump hoops like that. The LVB discharges are down to about 40% SOC before the truck shuts things down and charges it. I have the updated sensor but I think that only fixes a calibration issue. No OBD2 monitoring.
Now I simply plug in my 5 amp battery maintainer when I know I won’t drive for a couple of days. I really think it is just the number of deep cycles that kill the LVB. I have 2-3 discharges per week down to 50-60% which the LVB isn’t happy with.
GoodSam
Good
occupying space
My understanding is that the lead acid battery longest life is attained by keeping it fully charged. Shame if Ford is not doing that when there is a nice big HV battery to draw from.
Adventureboy
True for flooded lead-acid batteries. For AGM batteries, slightly less than fully charged is better as it reduces the risk of burning the plates. AGM is happy around 80-90% SOC long term. Our trucks do this but only when running or when charging the HVB. It does not manage the discharge until it senses an "emergency" situation at 40% which is simply too low. Below 50% for any length of time is quite hard on them, especially repeated discharges or longer times spent below 60-70%. A maintenance profile that kicks in around 70% and charges to 100% and maintains to say 90% would work well. Do that 10 times before shutting the truck down, and all would be well.
Kansan
Wayne
2024 Flash
Civil Engineer
On my extended vacation in January I found that departure times didn’t have that limit. The truck sat for 18 days plugged in and it probably woke up for at least a half dozen departure events.
I also found that the charge from a 20 minute warming session resulted in a net loss in LVB charge. The modules stay awake for a half hour after the event and consume more charge than the system adds. Maybe a 30 minute session would result in a small increase in LVB SOC. It’s also possible that the charge rate in warmer weather might be higher resulting in a better net charge
I think it’s just climate starts that have the limit.
Interesting, I've experienced the opposite, maybe there has been a modification of the logic since initial production, I haven't tried exceeding the assumed limitations since experiencing them in 2022.
Maybe your 2024 and others have yet another undocumented feature?
We've experimented with having the HVAC blower motor set at manual medium/high causes a higher output rate from the DC/DC inverter, this was the case when leaving the truck running from Push to Start and letting the 30 minute timer run to expiration. These tests were done prior to the release of the improved LVB BMS, again MY22/MY23 trucks, while MY24+ have better everything, possibly improved base logic from the factory.
Lytning
Georgia
I eliminated my LVB issues 2 years ago with the Ohmmu H3+. 19 lbs lighter and worry free. 54k miles and counting.
The Ohmmu website currently shows 2 batteries for the Lightning ... a Sodium battery and a Lithium battery. I assume you are using the Lithium battery. I read where the Ohmmu app displays 12 volt SOC. Out of curiosity, what SOC do you usually find the battery is at?
johnnyonetime
FL
2022 Lariat ER
Yes I have the lithium battery and SOC is typically around 90%. Wife just got home from a short trip and this a screenshot from the app.
Ford F-150 Lightning Bigger front battery? IMG_1610
jwrezz
1996 Ford ExplorerXLT, 2006 Subaru OBS LLBean, 2024 Ford F150 Lightning Lariat
Teacher/Firefighter
That would be similar to stepping from the H3 to the H4. They are the same price and still more expensive than the more popular, higher capacity H5 and H6. I don't think anyone knows for sure how that will work out until one of us tries it. :sunglasses: I've never needed to jump start it because the truck shuts down the modules and charges the LVB anyway as I can see on my monitor.
Checking all things about possible replacements and came across this thread. Has anyone tried an H5 or H6 or are they way too big for any cutting of the stock tray as with the H4 size? If I can save money AND increase capacity, I'm for it. The ohmmu battery is way too much for me. There are other heated LiFePo4 batteries available but often with the need for terminal adaptation.
Adventureboy
Stock tray will fit H4 with minor trimming. I have a thread on this and highly recommend it.
H5 or H6 would require more extensive modifications since the original tray will not accommodate. You would have to fabricate a new tray that sits on top of the existing tray to give you the width and you'd have to test fit to make sure the cables are long enough for the raised tray and additional width of the H5/H6. Its probably possible however, more work.
