FCSP Software Version 2.112.125:3.15:3.15:3.15:3.15
I just found it strange that if I changed the FCSP setting from the 40s up to the max 80 amp that it would briefly increase but then go back down so that is why I decided to go to 79 A and when I did that it held. I used to always leave it at 80 amp, but then I was paying for electricity as I have solar, but not enough to run it at 80 A. if I am home early enough in the day to utilize the excess solar (I am producing 12 or 13 kW and the house is using 1 or 2 kW and the power wall is already fully charged)I derate the FCSP to match my excess solar production rather than sending it back to the grid, I’d rather put it in my truck if needed. Hopefully that makes sense. If it is cloudy or dark and I need to charge then I would set it to 80 amp.
Yes, understand your motivation, but I don't think Siemens intended for us to make dynamic adjustments in the course of a daily solar production cycle, 79/80 is close enough for government work IMHO, at least you have some flexible control in this situation.
F150ROD
U.S. Navy Retired
Well I was finally able to reconnect to WiFi after about a year.
is there anyway to force this update or do I just let it happen?
Leave her alone overnight, then do a power cycle in the morning.
F150ROD
U.S. Navy Retired
Power Cycled and updated! Thank you.... now to trouble shoot why my Lightning thinks it's at 100% Charge and stops charging :unsure:
Ford F-150 Lightning FCSP Software Version 2.112.125:3.15:3.15:3.15:3.15 IMG_4843
Corrupted charging profile in the truck, review the saved charging schemes, edit or delete/replace with new schemes.
F150ROD
U.S. Navy Retired
Unfortunately, Ive tried all the basic stuff. Next step is Ford Service unfortunately. I think its related to this thread 23-er-not-charging.26831
Status quo the majority of 2025, last firmware change was around 3/26/2025
Ford F-150 Lightning FCSP Software Version 2.112.125:3.15:3.15:3.15:3.15 1763210353669-hg
As of 3/19/2026 this version is still current
Ford F-150 Lightning FCSP Software Version 2.112.125:3.15:3.15:3.15:3.15 1773948137929-rv
I <3 My Lightning
Ditto... What I do find interesting is anytime I see one of these units up for sale, even when they were still shipping them and giving them as part of the free install, the boxes all had the same manufacture date. Then must of had thousands of those stockpiled.
