FCSP Software Version 2.112.125:3.15:3.15:3.15:3.15
I just found it strange that if I changed the FCSP setting from the 40s up to the max 80 amp that it would briefly increase but then go back down so that is why I decided to go to 79 A and when I did that it held. I used to always leave it at 80 amp, but then I was paying for electricity as I have solar, but not enough to run it at 80 A. if I am home early enough in the day to utilize the excess solar (I am producing 12 or 13 kW and the house is using 1 or 2 kW and the power wall is already fully charged)I derate the FCSP to match my excess solar production rather than sending it back to the grid, Iโ€™d rather put it in my truck if needed. Hopefully that makes sense. If it is cloudy or dark and I need to charge then I would set it to 80 amp.
Yes, understand your motivation, but I don't think Siemens intended for us to make dynamic adjustments in the course of a daily solar production cycle, 79/80 is close enough for government work IMHO, at least you have some flexible control in this situation.
F150ROD
U.S. Navy Retired
Well I was finally able to reconnect to WiFi after about a year.
is there anyway to force this update or do I just let it happen?
Leave her alone overnight, then do a power cycle in the morning.
F150ROD
U.S. Navy Retired
Power Cycled and updated! Thank you.... now to trouble shoot why my Lightning thinks it's at 100% Charge and stops charging :unsure:
Ford F-150 Lightning FCSP Software Version 2.112.125:3.15:3.15:3.15:3.15 IMG_4843
Corrupted charging profile in the truck, review the saved charging schemes, edit or delete/replace with new schemes.
F150ROD
U.S. Navy Retired
Unfortunately, Ive tried all the basic stuff. Next step is Ford Service unfortunately. I think its related to this thread 23-er-not-charging.26831
