UncleTony
I appreciate the offer, could you just share the files instead? I am able to print it myself to save you the cost.DM me your address and I'll throw one of the 3D printed boxes in the mail if you want.
Hoping to get my Comma set for a trial run this afternoon. Has BluePilot been updated or should I use Open or Sunny?You can run stock OpenPilot until we get BluePilot updated.
but we should have it updated early next week anyways.
installer.comma.ai/BluePilotDev/staging-2.1Hoping to get my Comma set for a trial run this afternoon. Has BluePilot been updated or should I use Open or Sunny?
I have tried downloading bluepilot four times now. The downloading bar goes to 10%, then the screen goes to the comma logo, then it goes to the "let's get started" screen. I made sure to copy your URL with the capital letters.installer.comma.ai/BluePilotDev/staging-2.1
Be sure to go into the bluepilot menu and set your tuning profile to low. The default is mid and that will be uncomfortable on an F150
OpenPilot doesn't download, it's stored on the harddrive. Try a different wifi, or move closer to wifi, or hotspot your phone. It's a network issue 95% of the timeI have tried downloading bluepilot four times now. The downloading bar goes to 10%, then the screen goes to the comma logo, then it goes to the "let's get started" screen. I made sure to copy your URL with the capital letters.
Openpilot downloaded on the first try.
Any suggestions?
Success with the hotspot ?OpenPilot doesn't download, it's stored on the harddrive. Try a different wifi, or move closer to wifi, or hotspot your phone. It's a network issue 95% of the time
The comma gave me the "resume control warnings" through the comma screen and then shut everything down. I assume it was being controlled through the comma, or at least I want to hope it was being controlled through the comma ?It might be defaulting to Ford ACC. Check the developer menu for Sunnypilot longitudinal control if you want to use OP ACC
Comma is always in charge of steering, but you can choose wether it uses its own logic for ACC, or passes through fords stock messages.The comma gave me the "resume control warnings" through the comma screen and then shut everything down. I assume it was being controlled through the comma, or at least I want to hope it was being controlled through the comma ?
Once my mount has finished its "48 hour curing" process. I will reset everything and start over. I'm sure I will have plenty of questions about the calibration settings in 2 days...
Make sure you type in the installer address for bluepilot exactly as shown. Including the uppercase letters. I didn’t know that mattered as normally for a web address it does not but here it does. I had the same issue of it stopping at 10% ajzride set me straight. ?The comma gave me the "resume control warnings" through the comma screen and then shut everything down. I assume it was being controlled through the comma, or at least I want to hope it was being controlled through the comma ?
Can I plug in the Comma to a USB at my desk for power to do all of the downloading and adjustments and then go to the truck for calibration?installer.comma.ai/BluePilotDev/staging-3.0
Yes.Can I plug in the Comma to a USB at my desk for power to do all of the downloading and adjustments and then go to the truck for calibration?
