Service vehicle soon - Failure Coolant Valve Not covered by powertrain warranty?
jallen
2009 F150 XLT / 2023 Ford Lightning Pro
I literally just had a stuck coolant valve replaced this week under warranty. Many are going bad and it’s a known issue. I really don’t think dropping the battery is true!!! They replaced mine in an hour! I dont think they even took the frunk tub out, maybe they did…you can see the part they replaced when you open the 12v battery door!
Ford F-150 Lightning Service vehicle soon - Failure Coolant Valve Not covered by powertrain warranty? IMG_6249
Ford F-150 Lightning Service vehicle soon - Failure Coolant Valve Not covered by powertrain warranty? IMG_6254
Ford F-150 Lightning Service vehicle soon - Failure Coolant Valve Not covered by powertrain warranty? IMG_5473
Scorpio3d
SS/IBA car wash owner
Frunk tub removal is pretty easy took maybe five minutes by myself!
flyct
Jerry
South Florida
2024 Ford Lightning Platinum 2024 F-450 Platinum & 2-2023 Tesla Model Ys
Blissfully Retired
No your description was great! I will say I bought the warranty for my 22 Platinum a few weeks ago... Just needed a US address. Looking online it seems many others have had success as well, I guess if it doesn't work I can always request a refund, which they do.
Yes that will work, as long as it's not Florida or California. We spend time at my Brother in Laws house in NC in the heat of the summer. We looked into using that address to get a ESP.
would anyone to do the remote code reading for free?
The codes are sent to the Ford servers. All the service person has to do is look it up online. Any competent dealer can do it, if they're smart they won't charge a fee.
As far as the valve, where is it located? I don't recall anything in the battery box except batteries. A previous poster says it's near the 12v and is easy to change.
jallen
Take off slide door in Frunk for 12v access. Stick head and flashlight in and look to the right. It will be there.
With battery out of the way you may be able to do job, but removing Frunk tub is obviously the correct way to have the room to work.
On a side note, not sure why anybody would pay Ford dealer to read a code when ForScan is free to read codes, and something like $20 a year to be able to do more invasive procedures.
Now, doing the work, with disconnecting the coolant lines and maybe purging air, etc it’s understandable if you want dealer to do.
Base Trailer Tow - With 2.4kW Pro Power Onboard
Ford F-150 Lightning Service vehicle soon - Failure Coolant Valve Not covered by powertrain warranty? 1744894429176-hx
Ford F-150 Lightning Service vehicle soon - Failure Coolant Valve Not covered by powertrain warranty? 1744895530710-0k
#17 is diverter valve to radiator and #24 is also a diverter valve, this one might be buried under what used to be the transmission hump area.
Ford F-150 Lightning Service vehicle soon - Failure Coolant Valve Not covered by powertrain warranty? 1744894795475-9q
Ford F-150 Lightning Service vehicle soon - Failure Coolant Valve Not covered by powertrain warranty? 1744894715131-ye
Max Trailer Tow - With 9.6kW Pro Power Onboard #15 & #22
Ford F-150 Lightning Service vehicle soon - Failure Coolant Valve Not covered by powertrain warranty? 1744895032198-va
Ford F-150 Lightning Service vehicle soon - Failure Coolant Valve Not covered by powertrain warranty? 1744895090452-o1
jallen
Great information! Thanks. Looks like the one I had replaced was by far the easiest one to access.
ytwytw
Toronto, Canada
2023 F150 Lighting ER Lariat
Update:
I asked the dealer to move forward yesterday, and today they dropped the battery and found HV pack has some coolant leak
They will continue the investigation on Monday to see the source of leak, and I will get the forum members updated
I might check with either Mike or ragu(?) to see if they can assist to pull it from Ford Server
Sadly I just lent out my mongoose to fix his Escape and now I don't have cable to do diag myself
The Weatherman
Dean
South Central KY
Update:
If there is indeed a leak in the battery pack, you might get some of the repair done under the 8/100 warranty. Ie., pulling the battery and replacing the fluid at a minimum.
Just a thought from an uneducated novice.
ytwytw
Toronto, Canada
Ford F-150 Lightning Service vehicle soon - Failure Coolant Valve Not covered by powertrain warranty? 1747015379120-pw
Ford F-150 Lightning Service vehicle soon - Failure Coolant Valve Not covered by powertrain warranty? 1747015414354-6x
I am happy to report my truck got fixed for a price that is much lower than the original value
originally the cost could near $1800++ but the dealer really helped me out and give me a giant discount to a much lower value (I cant disclose the amount unfortunately)
based on @TaxmanHog pic, I guess the divert value is indeed on front of the battery and may require battery drop to disconnect? i don't have service manual so not sure (can I get it in FDRS subscription?)
I hope the paperwork can shed some lights to other lightning owners when you see the engine light error lol
also worth to mention, none of them are covered by HV warranty, even its HV coolant system faulty part
GoodSam
Good
occupying space
I think the diverter valve is just to the right of the 12V battery, requiring the frunk to be lifted out of the way.
Looks like they did not diagnose the Powertrain fault warning on the dash? I would think that they would easily see the diagnostic code with their equipment while they were doing the other work.
Excellent news, that part is not too expensive, this diagram points out the location, seems like it was the upper unit near the LVB
Ford F-150 Lightning Service vehicle soon - Failure Coolant Valve Not covered by powertrain warranty? 1747054590232-76
Ford F-150 Lightning Service vehicle soon - Failure Coolant Valve Not covered by powertrain warranty? 1747054663120-5s
ytwytw
Toronto, Canada
The 10h labour is a lot of money actually... part price seems reasonable to me
