COrocket
F-150
If I do the IPMA and other modules myself, will the front camera CSP in FordPass go away? Or is reporting that complete a dealer function?
kzoojason76
Jason
2024 F150 Lightning Flash
The latest APIM update is now available in FDRS. It was jsut released as of this morning for mine.
Some reason late Build 24s stopped at LR and never got NG.
So mine goes straight from LR to NM.
22 up Lightnings should have it showing now along with Mach E
Ice Trucks are also showing it from 22 up
I think you just cost me $50 :). Time to buy a 2 days license to update the Flash!
Jesse-Infotainment
2024 F150 Lightning Platinum
If you send the vin I can tell you how many updates you have..
As of a day ago I had no APIM updates. I hesitate to ask anyone to check my VIN again, but alas here I am. I don’t want to purchase the sub if I don’t have it available.
Message me after 7pm when I'm home and have my laptop and I'll check for you.
Thanks Jesse. Where can I see the values NG or NR?
I just see values from F188, F124, etc.
I believe it is in the 8033 DID. Going from memory here, but I'm pretty sure that's it.
Edit: Yea, that's it. This is from your truck.
Ford F-150 Lightning Lightning Software Updates using FDRS 1747938202870-pm
In the case that the vehicle was on another older version of Sync, it will look very different as the update packet is more extensive. Like this:
Ford F-150 Lightning Lightning Software Updates using FDRS 1747938331973-
Thanks Javier! I don't have full time access to PTS so I use the poor man's method of looking at version numbers / DIDs in FORScan or in As-Built files on the MotorCraft site.
The thing is, AFAIK, FORScan won't show you what you came from.....only what is there now. You'd have to document what is there pre and post the OTA to compare without PTS.
Yeah, I got that covered! I do exactly what you suggest. I use FORScan Lite or CarScanner since I don't have to get the laptop out. FORScan Lite works well - you just have to clear the cache before connecting.
I also download from MotorCraft before and after. I have seen that site update almost immediately after an OTA installs.
Correct. An OTA causes the server interrogator to poll the vehicle and reports the data back to the mothership almost instantly.
mr.Magoo
2022 Lariat ER, AMB
I just updated mine again (last time was in Febuary-ish), had quite a few that needed to be done, incl. the pesky ACM / RFA that just won't go away.
majorgearhead
Summerville, SC
2023 Ford Lightning Lariat ER
Computer Systems Engineer
I just used FDRS to apply the new APIM update. All of my settings for WAL and BlueCruise stayed the same thankfully. Other than that, not a lot that seems different. Still cannot set a profile photo any longer. This was a regression in one of the last couple APIM updates. For that bug, if you have profile photos set from earlier, don’t delete them as you can’t assign them anymore.
I just used FDRS to apply the new APIM update. All of my settings for WAL and BlueCruise stayed the same thankfully. Other than that, not a lot that seems different. Still cannot set a prifule photo any longer. This was a regression in one of the last couple APIM updates. For that bug, if you have profile photos set from earlier, don’t delete them as you can’t assign them anymore.
Thanks for this update. Profiles started off pretty cool and were easy to set up. They seems to have gone down hill since early on.
Jesse-Infotainment
213 is the owner manual.
14g632 is the OS load.
Kyler721
Kyle
2023 F-150 Lightning
Cyber Security
Yes. The update that adds the toggles back has only been released to EA members. It does not show up in the latest FDRS pull of modules needing update. Hopefully it will in a few weeks. Until then I enabled it in Forscan some time ago, so I am not too worried.
Can youn detail what line of code you changed in FORScan to add the toggles back?
