2025 Flash - Battery Size Determination PSA
I assumed my truck had 2 chargers, one being 110vac and the other being 220vac
i’m still confused, does the single charger accept 110 and 220v ? Do the duel chargers charge different parts of the hv battery or do they operate in parallel to charge the hv battery.
Here is a cut-down version of what the Workshop Manual says:
AC Charging
The SOBDM , also known as the On-board Battery Charger Control Module (BCCM) is a liquid-cooled component that charges the high voltage battery [from both 120V and 240V EVSEs]. ...The primary function of the Secondary On-Board Diagnostic Control Module A (SOBDM) is to coordinate charging operations and convert AC from the EVSE to DC. ....
Some vehicles are equipped with a secondary On-board Battery Charger Control Module (BCCM), also known as the GFM2 ... provides additional charging capacity for the high voltage battery when an high output level 2 EVSE is utilized. The primary On-board Battery Charger Control Module (BCCM), communicates and controls operations of the GFM2 via dedicated communication circuits.
While no amp limit is mentioned, the SOBDM (primary charger) is good for 48 amps so I suspect the GFM2 kicks in above 48A. But the manual doesn't say.
ER Battery difference of 8kWh and 20miles estimated range (6.25% range or 6.11% kWh) will save Ford some money and they probably figured buyers would not miss the 20 miles of range?
Dual AC-DC converters: They say the "secondary On-board Battery Charger Control Module (BCCM), also known as the GFM2 provides additional charging capacity for the high voltage battery when an high output level 2 EVSE is utilized..." does sound like it kicks in when the EVSE supplies (AC) current above 48A.
The ER Lightning has two onboard chargers, capable of converting a total of up to 19.2kW of power (80A at 240V).
With just one AC-DC converter, the SR Lightning can convert up to 11.520kW of power (48A at 240V).
19.2kW - 11.52kW = 7.680kW, so the second AC-DC converter does not need to operate at 48A.
I imagine they are two identical AC-DC converters and when operating at a total of 80A the current is split between them evenly 40A-40A under control of the BCCM's.
The 80A max AC current maybe a practical consideration wrt to home installation of the FCSP, the cooling needs of the converters, or some other factors.
Two 48A AC-DC converters should be able to handle 96A.
A 96A EVSE would have to be wired with 120A circuitry (the 80% continuous load rule) which might have been considered impractical for most residences?
Maybe someone on the design team has the answer to that?
BSEE SPARKY
Derek
Southern Indiana
2023 Lightning Lariat ER, MAX TOW, Power Running Boards
Is this a tariff thing? Don't the batteries come from China? Probably allows them to keep cost to produce closer to current.
If that were the case, would it only affect the Flash trim?
Also, the 131kWh battery was actually a 143kWh battery with 12kWh headroom for safety/longevity. The headroom buffer changes the depth of charge/discharge which helps battery health.
So the 122kWh battery is really something larger maybe 8% larger with the headroom, for what its worth. 131 is about 92% of 143.
AI tells me this:
"Ford is reducing the capacity of the F-150 Lightning Flash trim's extended battery from 131 kWh to 122 kWh as part of Job #2 production changes. This change affects the 2025 model year. While the specific reasons for this reduction aren't explicitly stated in the search results, it's likely due to a combination of factors, including potential cost savings, adjustments to battery cell chemistry, and changes in manufacturing processes."
"Looks like they are also getting rid of the spare tire. Replaced with a sealant kit and an inflator."
Some other speculation:
" Saves them some cost per truck and lets them stretch out their inventory of battery modules. Probably to hold them over until they start using the new batteries from their US plants later this year or next year."
irunalot
2025 F150 Lightning
Jumping on this thread - someone please redirect me if I'm on the wrong one.
I have a 2025 Lariat with ER battery. I also have a professionally installed FPSP with 100A circuit. I've voluntarily set it to 48A using the internal current limiting dial. It's worked well for months. Today, however, I needed more juice in a hurry. I opened the cover and set it to 80A and... the truck says the max is 48A under the Advanced screen and my Ford Pass App says the same (max slider setting is 48A). People online are talking about one or two onboard chargers for AC charging. How can I tell what my specific truck has? Can the external temp be limiting my charge? It's 94 degrees F today?
Thanks in advance!
Thanks in advance!
Beginning in 2024 all Lightnings (except certain fleet models) have a single onboard charger and are limited to 48A. See your window sticker to confirm:
Ford F-150 Lightning 2025 Flash - Battery Size Determination PSA 1750642038858-ns
irunalot
2025 F150 Lightning
Yup. I see it now. My sticker says single. Very sad.
Thanks for the quick reply.
Yeah, I'm not a fan of Ford giving out the FCSP as part of their Power Promise. They make a 48A charger that would have matched better.
The bad thing is folks like you paid a lot more for a 100A circuit instead of the 60A you could use. Of course your next EV could take advantage of it.
irunalot
2025 F150 Lightning
I see that now as well. It's a 7 alright. I'm not happy at all. I'll be smarter next year.
So what models do come with the dual chargers?
2022 and 2023 ER. For 2024 and 2025, fleet dealers could order a Pro or Flash with dual charger. But not available on the Lariat or Platinum.
But a ton of us use 48A happily even though our trucks can do 80A. Only in rare cases do folks find they need the 80A (long daily commutes combined with a short charging window).
irunalot
2025 F150 Lightning
Yes, agreed. I've been perfectly happy with 48A. I just needed a quicker jolt today and was disappointed.
I order Ford products annually and I'll look out for this next year.
For now, I'm really enjoying my Lariat. It's a fantastic work of engineering.
Thanks again for all the replies!!
GoodSam
Good
occupying space
One advantage would be that the truck could power the house directly with its DC Volts/Amps via the CCS cable?
