mattskr
Matt
Austin, Texas
23 Platinum Iconic Silver
IIRC, it also seemed for some people that it wouldn't show the AM tab initially. But if you clicked the input numpad and entered an AM frequency, it would show.
And this guy figured how to do it with FORScan:
https://www.f150lightningforum.com/forum/threads/enable-am-radio-on-2023-lightning.15641/
I had the opposite issue. After the update the AM Radio tab showed up but selecting it did nothing as this video shows:
It turns out my AM tuner was not actually enabled in the Audio module. The following Forscan change fixed the issue for me:
Code:
ACM 727-01-02 xxxx x0xx xx--
change from 1 (disabled) to 0 (am enabled)
Thanks @bmwhitetx for helping me find this.
If what you're missing is the option for AM radio on the touchscreen, it can be added with FORScan by enabling it here.
If you have an 8, change it to a 0. If you have a 9, change it a 1 and so on.
Ford F-150 Lightning Priority Update: 23-PU0110-RAD-PS 1740262026794-r2
So in summary, it appears these two changes will enable AM radio (2023 Lightning specific):
ACM 727-01-02 xxxx x0xx xx-- change from 1 (disabled) to 0 enabled
APIM 7D0-01-01 xxxx x2xx xx-- change from A to 2
In looking at my 50+ Lightning database, all but one vehicle had the APIM set at 2 and almost everyone had the ACM change except Matt and a few others. So sounds like the OTA mostly worked.
rockfish
Rock
Shoreacres Texas
23 Lariat, Star white. ER Max tow.
aircraft mx.
just received this update yesterday evening.
23-PUO1101-RAD-PS
NAVEWO
Tucson, Arizona
2023 Ford F150 Lightning Lariat ER Max Tow
Retired USAF Navigator/Electronic Warfare Officer
Just received this update for my truck today.
Priority Update 23-PU0110-RAD-PS
LazyLightningATX
Doug
Austin
'23 Lariat ER
same, I guess 'priority' means something different to Ford. this update came out going on 2 years ago! my first OTA since last Sept, so I guess i got that going for me...
Someone plugged in the distro server recently...........................
NAVEWO
Tucson, Arizona
Just checked and while the update does not mention it… turns out my AM radio works now. I’ve had the AM button for some time but it would not tune any stations. Now it works
ytwytw
Toronto, Canada
2023 F150 Lighting ER Lariat
Got this update 30min ago
Was hoping BCM but nope
also surprised this update isn’t available in FDRS
