What is this?
kf59
Ken
4$a7Yaofbfutc
Found two on the garage floor where I park the Lightning. Looks like a drain plug but for what
Ford F-150 Lightning What is this? IMG_2222
The Weatherman
Dean
South Central KY
Shoot another angle, is it hollow in the center?
Could be a wire pass through bushing, body hole plug?
Mach Turtle
Central California
2021 Mach E, 2024 XLT
Bum
Perhaps a photo taken with a ruler next to the item would help us judge the scale.
Maybe you have a low end model and this is the plug for the unused wires and hoses that go from the traction battery to the AI Powered Intimate Massager on a Platinum?
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
definitely ear plugs - use them when in traffic with ICE especially Diesel
seriously thou, could they be door or frame plugs - the ones that get pulled to do undercoating work, then the tech doesn't bother to push them all the way in again after spraying... :unsure:
Jon
2023 LIGHTNING XLT
Trades
It keeps the lightning in the bottle that powers the PDU & SDU...
or it's the drain sleeves that exit from the front of the bed, on each side, thru the wheel wells...
kf59
Ken
4$a7Yaofbfutc
It’s a solid rubber plug about an inch long with no drain hole. Google Lens brings up a Kubota tractor plug upon searching, but I don’t have a Kubota tractor.
Sgt. Carter
2022 Lariat ER (511a) Star White
Without having a real clue, I’d say it’s some sort of bumper plug. Depending on size it could be from one of the doors, where the bed rests on the frame, or another place under the truck.
Levi8than
Joe
2023 f150 lightning lariat
Electrics Engineer
I would guess it has nothing to do with the truck. If it's hard, it could be pex crimp plugs dropped by a plumber. If soft, maybe rubber feet from the underside of a tube steel shelf unit, barstool, or tool.
The Weatherman
Dean
South Central KY
@Martin Rebuilds , Maybe our Lightning rebuild expert can weigh in.
He may have seen them before.
Altivec
Kind of looks like the charge door bumper stopper.
Take them to the local Ford parts counter and tell the guy you need 100 more of them and he'll look it up for you?
