Help requested - Audio not working. Update - truck is dead
Jesse-Infotainment
2024 F150 Lightning Platinum
Probably the APIM, seems like Ford doesn't want to use one that's worth a damn. They've had constant issues with APIM's on all models for years. An ESP is in my future if I decide to keep the truck that much is certain.
Problem is all the codes show it is loss of comms with ACM.. so ACM isnt being seen
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
Got your message, but I'll post the response here for the sake of the info being out there. It does not seem like your issue will be fixed by a simple reset; not sure.....maybe @Jesse-Infotainment can chime in. The truck is reporting these codes relevant to your issue:
Hard to say if the DSP itself took a crap or if the APIM is the issue, but seems like the APIM itself has an issue.
I can check the DTCs when I get home on AllData. Is this from FDRS?
RLXXI
S. E. Louisiana
Auto tech
Thanks for pointing that out, I must have glanced right over it but yeah there's clearly a network issue, is it a frayed wire, rodent gnawed on, bad com chip, pushed out connector pin etc... I don't have access to these models wsm to check and my dealer days passed on 21 years ago.
Edit: Trying to get up to speed on this breed of machine, got one sitting under the carport. :bandit:
sotek2345
sotek2345
Engineering Manager
Thank you all so much for all of this help!
Any chance those buttons on the steering wheel have gone bad or causing issues? The experts have weighed in, but that is the fist thing that hit me when you described the problem about BC too. I know they've got codes and other data to go on.
lightdawg
kerry
ford f150 lightning
Also check behind the back seat. Pull the cover off and check connections to amp. I had a similar issue and found the usb connection came apart causing no audio
Ted23Lightning
Ted
Hopefully this helps. Will also upload as a PDF.
Edit: NVM, for some reason it’s not letting me upload the 2 PDFs.
Ford F-150 Lightning Help requested - Audio not working. Update - truck is dead IMG_4404
Ford F-150 Lightning Help requested - Audio not working. Update - truck is dead IMG_4405
Ford F-150 Lightning Help requested - Audio not working. Update - truck is dead IMG_4406
Ford F-150 Lightning Help requested - Audio not working. Update - truck is dead IMG_4403
Ford F-150 Lightning Help requested - Audio not working. Update - truck is dead IMG_4409
Ford F-150 Lightning Help requested - Audio not working. Update - truck is dead IMG_4408
Ford F-150 Lightning Help requested - Audio not working. Update - truck is dead IMG_4407
Ford F-150 Lightning Help requested - Audio not working. Update - truck is dead IMG_4412
Ford F-150 Lightning Help requested - Audio not working. Update - truck is dead IMG_4411
Ford F-150 Lightning Help requested - Audio not working. Update - truck is dead IMG_4410
Ford F-150 Lightning Help requested - Audio not working. Update - truck is dead IMG_4415
Ford F-150 Lightning Help requested - Audio not working. Update - truck is dead IMG_4414
Ford F-150 Lightning Help requested - Audio not working. Update - truck is dead IMG_4413
sotek2345
sotek2345
Engineering Manager
So...my whole truck just died on the drive home. It fai d to charge at a slow charger and when I tried to start it I got the stop safely now message. Could I have a dead / dying 12v.
Ted23Lightning
Ted
With the previous DTCs, I would guesstimate that u have an open circuit somewhere causing a parasitic draw. Also may have a rodent issue with noticing more & more things not working. Just my .02
Sorry ur going thru this :crying:
Looks like about 3years on the truck so suspecting the AGM battery is not a bad guess.
With the way the Ford algorithm for maintaining the 12V battery is programmed that would not be surprising, just doesn't work to keep the battery healthy the way it should.
Try jumping it at the jump terminals under the Frunk passenger's side cover and see if things start working again. If you attach to the battery use the blue circles in this pic, not the red X's:
Ford F-150 Lightning Help requested - Audio not working. Update - truck is dead where to connect to LVB
Hope your still have the 3 years B-to-B warranty if it's the battery.
Seems like a trickle charger would be a good investment with these trucks.
Good luck.
sotek2345
sotek2345
Engineering Manager
Good luck.
Thanks. Tried a jump but it didn't help
Also, past 36k miles so let's hope the extended warranty covers at least some of it.
If Ford is as frugal as Mercedes (wifes car) they won't, (with respect to the 12v LVB), other issues should be covered.
sotek2345
sotek2345
Engineering Manager
Still waiting on that tow. 3.5 hours since I called Ford. Gotta love the promptness. In the meantime my wife was able to Uber to the airport, get a rental F159, driver back to us and we transferred everything over. We finished that 45 mins ago....
