Mike G
- First Name
- Mike
- Jan 6, 2022
- N. AL, USA
- 2022 F-150 Lightning, 2023(J1) Mach-E GT-PE
Don't feel bad at all....that's how I ended up enabling BlueCruise on my 2021 Mach-E back in March of '22.
The original leaders in getting BlueCruise to function was the F-150 forum guys. Months before the Mach-E forum. I had both a '21 F-150 Powerboost and a '21 Mach-E and I was getting nowhere with my dealer service enabling a feature I had paid for on both. So like others I bought the Mongoose and a FDRS subscription and a little PL2320 and got to work...on the truck first. This is before the TSB to enable BC was even out.
Well that actually worked (using the PL2320) due to the giant 12V battery in the Powerboost....So I was very pleased after updating all modules that I got the notification in FP that BC was now active.
And then I moved over to the Mach-E.....well everything was going fine...since you have to do a lot of shorter updates before you get to the IPMA......I mean, the CMR did cause me some concern when I saw the voltage dip down to 10.1V.
But then I started on the IPMA...and very quickly realized that I was in trouble. So I pulled the Powerboost alongside and ran an additional set of jumpers piggyback from the truck to the leads from the PL2320 connected to the jump points, and then had to keep making sure the ICE engine on the Powerboost (Stop/Start) kept running until the programming ended (like 3 hours later).
I immediately went in and ordered a PL6100 from Ebay and haven't looked back.
But you aren't the only one who's learned this lesson the hard way, believe me.
