digitaldad
That is indeed, good guidance! I will edit that post.I wish I had thought of this too but I have a box that should be sufficient to protect it.
One of the four 10mm bolts that you need to remove to get the shifter out is actually under the stowed position of the shifter so you should get that bolt out BEFORE you put the shifter down.
I had swapped in/out both stock and new rotary shifter twice before I made the final upgrade and only took the original bolts out once.
