BennyTheBeaver
@UncleTony
I will have an extra harness after I install the new couple and USB cable.
I already purchased, but send me a message.
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
14 adapters remain.
A couple notes.
1. The PCB version should be able to go anywhere you want on the USB C cable.
2. I recommend using https://a.co/d/ha61IbW if you want to install it directly to your harness box. (I use the "U Shape" but use the version that fits your install)
I thought I had already posted this, but I think it was in the Discord when the Forum was down.
Tingleyfeeling
Brent
Ford F 150 Lightning 2022
Maintenance
I just received my board from Uncle Tony and it is even better than I thought. After reading I could put it anywhere I wanted on the USB cable, I placed it at the start of the USB cable going to the windshield. It worked flawlessly. I have a quick release mount so I didn't have to change a thing and this way it is out of the sunlight. Thank you so much Uncle Tony!
P.S. Shout out to Ajzride and everyone involved with Bluepilot!
Ajzride
Alan
Houston
Eng
I’ve had lots of request over the years for a dash mounted quick dock. I’ve made a prototype that will fit on the LCD of a MachE or a Lightning. In my opinion, it’s as bad as I always thought it would be, I feel like it blocks more of the road rather than less, but I want some feedback from everyone else. Is this something you would be interested in if I finish the design? It takes a lot of hours and filament to work out all the final details in a design like this, and I’m not particularly inclined to keep going unless there is strong interest.
it really can’t be any lower, there is only 5mm of bracket over the top, any less would be too weak to support the comma.
Ford F-150 Lightning Comma AI self driver assistant IMG_4227
Ford F-150 Lightning Comma AI self driver assistant IMG_4226
Ford F-150 Lightning Comma AI self driver assistant IMG_4225
Ford F-150 Lightning Comma AI self driver assistant IMG_4224
Ford F-150 Lightning Comma AI self driver assistant IMG_4223
UncleTony
Tony
I've already given you my opinion on it, but in the sake of starting the feedback. It looks like it blocks a ton more than the windshield mount and I'm not the biggest fan of it being mounted to the screen. Granted the view may not be so bad in a lightning with a bigger windshield.
watts/up
23 Pro SR
This mount wouldn't work for my screen anyway but even if it did I would not be interested in this.
mkuntzman
Michael
2024 F150 Lighting Lariat
Construction Estimator
How has BP-4.0 been for people? Are there recommended settings?
UncleTony
Tony
RLXXI
3rd rock
Automotive Technician
BC 1.4 in my truck works great, am I missing something with this comma system?
RLXXI
3rd rock
Ajzride
Alan
Houston
Eng
I c he forced a beta version of BC 1.4 on his truck. I have the finished version so perhaps improvements were made after he tried it out? Works great for me is all I can say, even works off interstate on ground roads if the stripping is new enough to be seen.
Lane changes are smooth and precise with a flick of the turn lever.
He = Me.
I have the official version now, and nothing has changed.
BC1.4 will not do hands-free on a surface street with red lights and turn lanes, only on divided highways.
