MrLoganRoss
- First Name
- Logan
- Jul 28, 2024
- Seattle Washington
- '23.5 MachE GTPE & '24 Lightning Lariat
I need to have a better ground for a higher end audio system being installed in the truck. My understanding is that the ground points in the truck cabin back wall should not be used because the cabin is aluminum. Yet Ford grounds there. Doesn’t that mean they run a ground elsewhere?
nevertheless, I have two 4 gauge grounds that need to be run. Due to the BMS, where should they be run? Not the battery right? How about the negative post on the passenger side of the Frunk?
thanks!
thanks!
