DAS640
Daniel
Beaufort, SC
2024 Lightning Flash
HR Officer
I would start with reseating your cable. If you are using the 12 foot OEM comma cable, make sure you are plugging it in all the way. They are good at making your think they are seated.
I will reseat all cables later today and let you know if anything changes. Would be good if it were that simple. I know when I unplug the comma cable from the Q4 harness and restart the truck everything returns back to normal.
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
That's because the long cable is technically what causes the reflections. But the radar error sounds more like a cable issue.
WilliamRobert
Western Pennsylvania
2022 F-150 Lightning, 2023 Mustang Mach E
happily retired!
Need a little help trouble shooting, open pilot didn’t work, tried blue pilot 4.0. The pictures show the plug I was using .
Still not working , I did notice that all of the error codes are still active with only the usb-c is plugged in , with or without the comma being plugged in! Can’t I just solder the 360ohm resister into the “Ford Q4” harness? If so what wires?
Ford F-150 Lightning Comma AI self driver assistant IMG_0927
Ford F-150 Lightning Comma AI self driver assistant IMG_0924
Ajzride
Alan
Houston
Eng
You are in the right spot. Some warning are normal but they should clear up within a minute of booting. Did you get any messages on the Comma screen?
WilliamRobert
happily retired!
I did have to pair it with my account, there weren’t any error messages on the comma, this is a 2022 lightning lariat, for reference.
I’ll plug it in again and give it more time.
Ajzride
Alan
Houston
Eng
When you cranked the truck, did the screen on the comma show the cameras?
WilliamRobert
happily retired!
The Comma says, CAN Error check connections.
Ajzride
Alan
Houston
Eng
99% of the time this is a cabling issue. Do you have the long USB cable that comma sent? If so it has been found to be hard to plug in. You have to push it until it clicks, which can take firm pressure.
You can always remove the device from the windshield, connect it under the dash with just the short cable that comma sent to help determine if the long cable is the issue.
WilliamRobert
happily retired!
Used the cable from my Apple laptop, fired right up, taking it for a test drive.
Thank you!
DAS640
Daniel
Beaufort, SC
HR Officer
Reseated all the cables and tried both the USB that came with the comma and a different USB (USB C 3.2 Gen 2X2 Video Cable, 20 Gbps Data Transfer, 240 W, 10ft) with the same issue. on start up I get Pre Collision Assist, Service Advance Trac, and steering assist. When I start driving I also get the other codes below. They do not go away until I unplug the USB and restart.
Ford F-150 Lightning Comma AI self driver assistant IMG_4540
Ford F-150 Lightning Comma AI self driver assistant IMG_4538
Ford F-150 Lightning Comma AI self driver assistant IMG_4537
Ford F-150 Lightning Comma AI self driver assistant IMG_4541
Ford F-150 Lightning Comma AI self driver assistant IMG_4536
Ford F-150 Lightning Comma AI self driver assistant IMG_4539
UncleTony
Tony
With everything plugged in. Turn the truck off and remote start it. Wait about 5 minutes before you turn on the ignition and see if the DTC's clear.
DAS640
Daniel
Beaufort, SC
HR Officer
Plugged everything in. Remote started for 5 minutes before starting. Did this several time. No joy. Could there be something I am overlooking?
UncleTony
Tony
No, just trying to separate the normal startup errors. If you are still getting errors, it is likely you have a hardware issue. Most of that should clear once openpilot/bluepilot takes over. Are you able to make a breakout board?
