PJnc284
Garner, NC
My question is where are your toggles? I can't find toggles for these features.
The toggles on the center screen are a separate update from the one that updates the ipma to allow lane change assist and repositioning. The latter came first and the features were enabled by default similar to wal and required a separate apim update to get the toggles. Sounds like @Diamond lightning may have down updates of order or something didn't update correctly. Out of curiosity, post your update pages. Top one adds the toggles and bottom is the one that actually enabled 1.4 features. If you happen to have forscan, you can verify/enable both
https://www.ford.com/support/software-update-release-notes-history/
Ford F-150 Lightning BlueCruise 1.4 is *officially* rolling out 1000011271
EVmeritus
Griff
2020 Tesla 3, 2022 F150 Lightning
Electrification Activist
I finally received the 1.4 update with the Walk Away Lock. I was able enable the Walk Away Lock Feature with no issue and it functions. I do seem to be having an issue with being able to enable In-Line Positioning and Lane Change Assist. When I toggle the button it will slide over for a second, stay grey, and then slide back. When driving the Lane Change Assist does not function.
Suggestions?
I'm having the same issue with a slight variation with In-Lane Repositioning and Lane Change assist.
I can toggle the slider for In-Lane Repositioning and it will turn blue for a couple of seconds then it will automatically toggle back to the off position.
The lane change assist will toggle to the right and will stay there but does not turn blue (to indicate it is active). And the vehicle will not automatically change lanes when Blue Cruise is engaged.
I've had the vehicle for over three years and would really like to have these features work. (Ford - Hope you are still monitoring this thread)
Ford F-150 Lightning BlueCruise 1.4 is *officially* rolling out IMG_7187
Ford F-150 Lightning BlueCruise 1.4 is *officially* rolling out IMG_7189
White F150 Lightning 2022
Mine does the exact same thing. I wrote at Ford Motor Company and they said they are seeing this in a few of the vehicles. I sent them my VIN. I’ll let you know if they’re able to fix it.
PJnc284
Garner, NC
Out of curiosity go to - FordServiceInfo.Com. Enter your vin and download your as-built config. You can change the extension to xml which should make the file a bit more readable in your web browser. Post what you have for 706-01-01, 706-01-02, 706-02-02 and 706-38-01.
706-01-01 8E50 A215 AE52
706-01-02
0000 0000 0010
706-02-02 E07F CE00 003E
706-38-01
F8FB E000 0019
PJnc284
Garner, NC
706-01-018E50A215
A255 (A259)
AE52
706-01-02
0000
0500 (3500)
00000010
706-02-02E07F
E47D (E47F)
CE00003E
02xx
706-38-01
F8FBE0000019
Looks like you may not have gotten the update that changes the ipma settings or it didn't apply correctly. Added the values below yours that appear to be different on mine. Regular values should be the 1.4 values. In parenthesis are mine which have changes to enable glare-free, trailer tow cameras and cameras at speed.
duncanmclain
Duncan
St. Louis, MO
F150 Lariat ER
Supreme Galactic Commander
706-01-02 0000 0000 0010
706-02-02 E47F CE00 0042
716-38-01 0000 0000 0056
PJnc284
Garner, NC
706-01-018E50A215AE52
706-01-02000000000010
706-02-02E47FCE000042
716-38-01000000000056
looks like you have the same problem. I'm assuming you meant 706 instead of 716? Do you have Forscan? You seem to have cameras at speed enabled based on the E47F. If so, you should be able to take what Diamond Lightning has and make the changes I noted.
duncanmclain
Duncan
St. Louis, MO
F150 Lariat ER
Spoke with the Ford OTA team earlier today. They confirmed that I received the first of two updates that will ultimately end with BlueCruise 1.4. They did look at the update and noticed that the OTA did not install but it had an error occurred in the process and that I would be queued up for it to be re-applied or a fix sent; they also said there many instances where this occurred. The recommended that I either wait for the OTA to come thru or take it to the dealer so they can reinstall the update but there might be a charge for it. Really? I charge to fix a bad update? I think I have like 3 days left on the manufacturer warranty.
I also spoke with them last week and they said the exact same thing. Honestly, quite frustrating that after paying over $80,000 for a truck, they can’t cover the cost of a faulty update. Hope they send out the fix soon.
edcoble
Fort Worth, Texas Ed
2023 Ford Lightning Lariat (ER)
Retired/former lawyer/former pastor
I got it about a month ago on my 2023 Lariat. Lane stability, lane- changing, and improved duration are major improvements over 1.3. So hapoy to have it!
duncanmclain
Duncan
St. Louis, MO
F150 Lariat ER
The OTA agent I spoke to earlier in the day contacted me and asked me to check to see if I could see a pending update. I checked and the 2nd part of the update was pending. Once I got home and parked it, I hit apply update, and finally 1.4, with all the toggles functioning. Just need to take it out on the road and see how it goes.
