Ford Charging Station Pro or Emporia Charger
To choose between the 2 I'd absolutely choose the Emporia. It has a standard J1772 plug that can charge most any other brand than Tesla. The Ford Charge Station Pro plug to car will not be able to charger a J1772 or Tesla car. Tesla's come with a J1772 to Tesla NACS adaptor that will work with the Emporia of ANY other EVSE with a J1772 plug except the Ford Charge Station pro.
Eventually all new EVs will come with a Tesla NACS.
But the gold standard in my opinion is a Tesla Universal Wall Connector EVSE. I have one at our house and another at our cabin.
That gold standard has many issues working with non-Teslas. Chevy Blazer EV, Rivian, BMWs...
flyct
Jerry
South Florida
2024 Ford Lightning Platinum 2024 F-450 Platinum & 2-2023 Tesla Model Ys
Blissfully Retired
First I’ve heard of issues. Mine has no issues charging Lyrics, Bolts or Fords..
The Wall Connector has 4 Modes. Perhaps the mode selection needs to be changed.
All. Vehicles
Only Tesla
Authorized Tesla Only
Compatibility Mode.
All. Vehicles
Only Tesla
Compatibility Mode.
If you read FB posts and such, all has been tried, and there is no remedy for some. Charger overheats. Hands thrown up. Surprised me too.
flyct
Jerry
South Florida
Blissfully Retired
Interesting. I wonder what was reported that overheats on the charger. Is it the NACS connector at adaptor or internal overheat in the wall unit?
I did a search and found this YouTube video.
Lake Placid Lightning
2023 Lariat SR w/510A
The Emporia is compatible with my utility company's time-of-day discounted rate plan, while the FCSP was not.
I only charge from midnight to 6am, and am able to utilize my utility company's "Charge Smart NY" plan, which provides a discount when using the compatible Emporia unit.
Ford F-150 Lightning Ford Charging Station Pro or Emporia Charger 1760108013243-4t
xwing
Okeana, OH
2023 F-150 Lightning
Go with the Emporia. I had a charging issue that I thought was a problem with the charger. Turns out it was with the truck charge controller. Emporia's customer service was great in helping diagnois the problem. My Ford dealer told me I had better diagnosis tools than they did. I was able to capture in real time screen shots of the charge issue.
bthanos
2023 F150 Lightning Platinum
System Architecture (retired)
My 23 Platinum only charges from 12am to 3pm. It’s a setting in the car for the home location. Ford CSP drives 80 amps no issue. I sell excess solar at higher rates to my utility. Lowest cost is per the TOU settings.
bryce
Bryce
2023 Lightning Lariat ER, 1999 Boxster
Emporia. FCSP is bulky and offers little advantage unless you have the home integration system.
FloridaMan655321
1973 F100, 2024 Flash
I bought the Tesla Universal charger. I'm glad I did because now a year later my wife bought a Tesla, so we can both easily use it. I also like the Tesla software for controlling what time it should charge instead of Ford.
FloridaMan655321
I wonder if they used the highest possible max amps. I could do 50 amps but chose 40 amps. I just felt it would be safer and that is plenty fast enough to charge overnight.
flyct
Jerry
South Florida
Blissfully Retired
We have a Universal Connector in my house garage on an 60 amp circuit. When it is set up in Tesla Install software you set the breaker size to 60 and output is set to 48 amps. It charges at 11.6 kWs. We have no issues charging our Lightning or our Teslas.
At our cabin we are limited to a 50 amp circuit without running a sub panel. The Wall Connector outputs 40 amps there or 9.6 kWs.
I had has To replace the 60a double pole breaker that feeds a shed sub panel with a 50/50 quad breaker. They don’t make a 60/60 quad breaker.
Ford F-150 Lightning Ford Charging Station Pro or Emporia Charger 1760298844287-01
bthanos
My FCSP charges at 16.2KW. It’s very nice to be able to start the charge at midnight and have it at 80% before 6am.
I have a short run outside connected to my house panel with a 100A breaker.
Also great to be able to top off before 3pm on typical errand days.
Ford F-150 Lightning Ford Charging Station Pro or Emporia Charger IMG_3578
