bthanos
2023 F150 Lightning Platinum
System Architecture (retired)
An easy way to do that in the app would be to simply highlight the corresponding padlock icon on the main screen of the app. I.e. highlight the locked padlock icon if the truck is locked.
App would have to query the truck periodically do do it. User could change the lock status manually in the truck which would get the app out of sync. This is why the status is not shown unless an explicit action is taken in the app.
GunnarH
Gunnar
San Francisco Bay Area, CA
2025 F-150 Lightning Lariat ER - Antimatter Blue
Good point. Or, you could have the user pull down to refresh to see the status. Then remove the status after 30 seconds until the user either locks/unlocks or refreshes again.
jwrezz
1996 Ford ExplorerXLT, 2006 Subaru OBS LLBean, 2024 Ford F150 Lightning Lariat
Teacher/Firefighter
I seen it on my charging screen last night, didn't capture the screen shot though, but I will tonight after a make a run to Logan airport this afternoon.
Bryce's post shows the est'd completion time, not sure if he was charging to 100% {FULL}, mine was to 90% set point
Ok I was wondering if the "Charging until..." Was telling me time until complete. I set my to 80% or 90% depending on mood, so it's not necessarily time to full, but to what ever one sets their charge limit.
Right, the time is to reaching your set SOC, in my case it's 90% and it's been pretty accurate in the past +/- 5 minutes for these lower values, but if going to 100% that time frame can vary quite a bit based on the amount of top-balancing needed on the pack.
This is the current end of week session going on now, shot taken 8:17 EDT:
Update post to include end of session record, ended 4 minutes past predicted end time.
Ford F-150 Lightning Ford app v6.0.0/6.1.0 FKA Ford Pass, IOS & Android 1761438008190-9a
Ford F-150 Lightning Ford app v6.0.0/6.1.0 FKA Ford Pass, IOS & Android 1761444906075-dd
MichiganAB
‘25 XLT Standard Range - Antimatter Blue
Does anyone know how to save adjustments to cabin temp after you turn on climate via the app?
Might be user error but I just realized that it doesn’t seem to be saving any real-time changes I make to cabin temp. Heated seats/defroster will enable/disable, but temp doesn’t change when I click out of the mini climate pop-up.
Maybe the vehicle is actually set to that temp but the app isn’t updating?
I hadn't noticed this, I've been leaving my temp set to 72°, same as in the truck on the Sync screen, I'll tinker with it this afternoons lunch run.
Jamchampnate
Nate
Utah
Ford lightning 23’ Lariat
Why does my Kia not have an issue with showing status? How did all my Teslas show me status in the app too?
Every car with an app I’ve used has been able to show me if my car is locked, running, etc. why not ford?
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
I reset the temp on my 2022 LER last week as I was enroute to the airport - changed from 74dF to 72dF and found the truck set at that temperature on arrival.
I set the temperature up to 75 from 72, it's holding as of now, I changed tab views, closed & re-opened the app, the value is still holding at 75.
NOTE, I expect the Sync screen will still show 72 once I get out to the truck when we're ready to leave, this has always been the case, adjusting the value via Ford App has never changed the value inside the truck, but the HVAC does warm up to a higher value per my request in the app, but once you "START" the truck to ready to drive mode, then the Sync value will over rule what was requested in the app, BTW, this is often the source why the HVAC will suddenly start sending cooler air to pull the cabin temp back to 72. If I really want to maintain 75 I need to bump up the number on the Sync screen.
Ford F-150 Lightning Ford app v6.0.0/6.1.0 FKA Ford Pass, IOS & Android 1761583663755-on
Ford F-150 Lightning Ford app v6.0.0/6.1.0 FKA Ford Pass, IOS & Android 1761583683533-ov
KSkel
Keith
DoD
6.1 iOS is out. No PPO under “utility” for me
Ford F-150 Lightning Ford app v6.0.0/6.1.0 FKA Ford Pass, IOS & Android IMG_0133
MichiganAB
Edit: Nevermind, updating to 6.1 like KSkel posted solved the bug, now the temperature saves!
Hmm, just tried it again now and same thing. Obviously a bit easier to show in a video but for me selecting out just resets it back to that original temp.
Ford F-150 Lightning Ford app v6.0.0/6.1.0 FKA Ford Pass, IOS & Android IMG_2761
Ford F-150 Lightning Ford app v6.0.0/6.1.0 FKA Ford Pass, IOS & Android IMG_2762
TechnoSwiss
2024 Ford F-150 Lightning Lariat Carbonized Gray Metalic
Electrical Engineer
LOL. So... I'm eating my words a little here. I got the date wrong. It's actually next week - and that was totally on me. Promise.
See! Would AI make a silly mistake like this!?
So... it's next next week, any update?
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
