My interest in a DIY kit that adds a J1772 port to the bed and allows CWD?
  • Total voters
    175
PJnc284
Garner, NC
yeah I have to put in 100mph to get those numbers. :cwl:
Ford F-150 Lightning Charging While Driving w/ Gas Generator in Bed (Range Extender for F-150 Lightning) - Testing 1761961322679-d
Correct the only reason unity is different is because the SR can charge at 11kW and the ER can charge at 19kW, You're correct it has nothing to do with battery size, but range does. And of course there are different efficiencies given different speeds for different conditions. All Lightning owners know that, that's why your range is half when pulling a trailer,,,,,,, given the same speed.
Something still isn't right about your #'s, show what equations you're using for the plots.
Here is an ER with 80% of battery getting 2.0mi/kWhr going 70 with 19kW of CWD:
https://www.wolframalpha.com/input?i=R+=+2.0+*+(t+*+19+++(0.8*131)),+R+=+t+*+70
Range = 458mi
If you were towing with the same truck at the same speed with 19kW of CWD plug in 1.3mi/kWhr and you get:
https://www.wolframalpha.com/input?i=R+=+1.3+*+(t+*+19+++(0.8*131)),+R+=+t+*+70
Range = 210mi
I'll look into it again, its been a while. I see what you are saying so I'll have to go back and do it again.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Thanks, I'm not criticizing you, I just want to fully understand the #'s and make sure everyone who's interested has the most accurate info. Even I have been wrong thinking about this a few times.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
I'll be following this closely. This unit I have linked should offer a long runtime and hold up to continuous use at 48 Amps....
Winco Portable Generator 14KW rated
Wow, only 26" tall and 14kW continuous with a Honda engine and assembled in the US. This is awesome, thanks for sharing. 82db though, ouch. If it's going on a trailer, it'll be fine but in the back of the bed it'll kill the awesomeness of the Lightning.
PJnc284
Garner, NC
That seems to be louder than the Westinghouse 20k. This guy has an interesting set up for his fifth wheel
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
Interesting
48A/58A max = 82% of max output (I wonder if the dB are a bit less at 80% load)
1.83 USG per hour at 82% load with 15gal tank = 8 hours run time.
Add a muffler box to quiet it down and your good to go?
edit: with lifting loops on the box
SLOPRO
Western OR
2022 Ford Lightning PRO SR
Aerospace manufacturing
Winco does design, engineering and assembly in house in the US. I was looking for a genset with the iGX800 EFI engine and this was what I found I would think as you continue testing you could reach out to Winco and get the same generator with a Honda GX800i EFI engine in a proper sound enclosure to reduce noise along with some proper lifting eyes for load/unload. I'm thinking a rear receiver mounted lift would be the most practical. They could likely have the user panel prepped for you to have neat access to hardwire a 48A charger.
I just think if you are pulling a constant ~80% of rated load the advantages of these foreign built inverter generators decline. Obviously, they have a cost advantage up front but properly designed with a 15-gallon tank this generator would have endurance and run for thousands of hours.
PJnc284
Garner, NC
Been quiet here so for those not on the Facepage, Martin just completed a 2k mile trip towing a Mustang and realized 48 amps just isn't going to cut it towing any decent load. He only averaged about 14.5 miles from the generator each leg due with an average efficiency of .8mi/kWh. One leg must've been especially bad as he apparently went from 80%-13% in only 13 miles and averaged .1mi/kWh. :shock:
Ford F-150 Lightning Owners Group
Martin Meek Jr. ·December 3 at 10:01 AM ·
***EVERDRIVE RANGE EXTENDER UPDATE***
Whats Everdrive? Look at my previous posts in the group, we explain it in detail. In short, its extending range through charging while driving. I will be posting a YouTube video on Martin Rebuilds about this entire trip soon as well.
**Brutal Honesty and Thoughts of our Everdrive Kit**
The lightning has some serious efficiency constraints that we all deal with. Everdrive definitely helps with that, and in some situations can double a F150 lightnings range. With that said, MATH IS MATH. The bottom line is this... Speed, wind and temp affect a BEV truck so much considering the poor aerodynamics. It will take half the energy added to the truck as it is consuming to make it "feel" worth it. The F150 lightning generally consumes 35kw running at 68mph (in perfect conditions), which means you need to add 17.5 kw to make it really move the needle. The lightning consumes upwards of 60-80kw while towing, so you need 30-40kw of energy to make the juice worth the squeeze.
Does Everdrive work for Towing?
The data below proves that using our EVERDRIVE kit does not move the needle far enough to be effective for long distance towing. 11kw of generator power added about 15% of range to this trip. 19kw would be roughly 20%. NOT a game changer for range extending, but a real game changer for eliminating range anxiety. Speed (wind resistance) is a killer when towing. It is NOT a linear curve for energy consumption. The faster you go the more exponential the consumption gets.
How about Everdrive not Towing?
Non-towing trips, Everdrive can be a real game changer, If you keep speed to a minimum (65 mph) and aren't in a large headwind or its "cold" outside. In perfect conditions, we can get over 450 miles from a ER lightning at 65mph, even more at slower speeds. When speed and wind are not working in your favor, Everdrive charging at 11 kwh can bring the range back to what it was during excellent conditions without a generator.
Final Everdrive thoughts!
We will continue to develop our Plug-n-Play Everdrive kit. There are still many folks who can drastically benefit from it. But if your looking to get 250-300 miles while towing by adding Everdrive and a generator, you wont. With that said, we are going to continue to explore DC generator options to give the lightning even more power to extend towing situations similar to what the EREV solutions OEM's are working on.
We honestly appreciate all the feedback and comments, good and bad, about this project. This honest transparent review is meant to level set the challenges and show everyone the TRUE results. not some inflated perfect world marketing fluff.
Zachary Scott Carpenter
Patrick Cheung
Trip Data
· Number of stops: 17
· Miles Traveled: 1945 mi
· Average Charge Speed 111.3 kW
· Average Charger Arrival % 19.5%
· Average Charger Departure % 82.71%
· Overall Average Travel Speed 59.77mph
· Highway Average Travel Speed 70mph
· Total Charging Time: 13.73 hrs
Cost Data
· Total Electric Cost $518.17
· Total Generator Cost $127.59
· Total Truck Fuel Cost $645.76
· Comparable Gas Truck Cost $398.83
· Cost Savings -$246.93
Everdrive Data
· Everdrive Energy Added 344.25 kWh
· Everdrive Miles Added 299.08 mi
· Everdrive Fuel Cost $127.59
· Charge Stops Saved 2.5
Ford F-150 Lightning Charging While Driving w/ Gas Generator in Bed (Range Extender for F-150 Lightning) - Testing 1764980490438-7r
ElectrifyingMe25
Trav
F150 Lightning, XLT, 2023
Patrick Cheung
Trip Data
Cost Data
Everdrive Data
My hat is off to you guys for the great trial you conducted on your Everdrive system. Your trailer load was quite heavy. I hope you'll do some more testing pulling a boat or something more common. However, you definitely found the upper limit.
On a positive note, the range extension for just driving is great.
I'm still interested in purchasing this system when you get all the wrinkles ironed out.
Thanks
PJnc284
Garner, NC
Think Martin has a bass boat that he's towed all over the place with a Lightning. That or maybe a small camper might yield better results. I'd offer to be a guinea pig since we fish year round here in SE NC but my results would probably be worse than the car trailer even if I could run at 80 amps. I only got .8mi/kWh at 60 on a warm day the one time I tried. :cwl:
While I applaud the idea, and the testing prowess, to see if this 'works', I have some thoughts:
- With my '22 LIGHTNING PRO SR already so quiet, where almost any road noise now is easily heard, I would hate think that I had to endure the constant noise of an running generator engine, right behind me, for hours on end.
- it seems like a lot of cost, modification, and loss of bed usage to be able to simply 'extend' range, with EV trucks already expensive, on their own. Any range extension equipment is also not going to be at a low cost.
- if the idea is to not have to Stop and Charge, or even Stop and FUEL, it sounds plausible, but, likely the owner may also be compelled to carry MULTIPLE gas cans, or, if they are REALLY smart, why not go ahead and install a secondary bed-mounted FUEL TANK, with Pump?
Now we're getting somewhere... building an F250 Superduty, with a little EV power, just in case.
potato
BC, Canada
2023 F150 Lightning XLT ER
Right, to me the appeal is adding a DIY range extender battery pack + inverter in the bed. If you add 30 or 40 kWh worth of batteries you could add some meaningful range for those increasingly rare situations when you need it, and charge and discharge it silently. Keep the tonneau cover closed and nobody is the wiser.
Like, if I am going somewhere in northern Canada where chargers are sparse, that could be the difference between being able to make the trip or not. But I fully admit such situations are highly unlikely and charging infrastructure is improving quickly.
PJnc284
Garner, NC
You're thinking something like this guy's set up. 40kWh would probably net ~36ish to the battery. At 70, that would be about 70 miles or ~25% boost here in good weather. Probably a lot more efficient route than a generator but not sure it'd be much use outside of the initial discharge due to charging. Along from the size and noise, the efficiency or lack thereof for a generator is crazy. Assuming a potential of 33.7kWh per gallon of gas, Martin used 1.7MWh of energy from gasoline to add about 300kWh to the battery. Curious how much worse that would be with a larger generator and 80 amp charging.
Texas Dan
Daniel
Stupid idea! If I wanted range extension I would have bought a hybrid. I have issues even with the concept of range extending batteries.
With range extending batteries you have two batteries you have to charge, could be a pain on long trips. Even when pulling an RV I would rather stop more often without a range extending battery in the RV than trying to charge two batteries at the same time. What we really need right now is a lot more DCFC chargers.
In the future we will need/have much faster chargers and EV batteries with much greater capacity but that won’t help us with the EVs we own now. These guys with all these great ideas should be trying to figure how to get us more DCFC chargers.
