AZT9
Peoria, AZ
@digitaldad
Well. That’s was a PITA driveway job but I’m very happy with the results! Thanks for all
Of your help with questions! After installing the front, I opted for .7 (2nd clip in the rear) and for what ever reason the front and rear are nearly level after letting everything settle! The camber is nearly gone! And the Icon Delta pro UCAs are great! Thanks again!
Ford F-150 Lightning Leveled Avalanche Lightning (Eibach Stage 1 & 35" Wild Peaks) IMG_9817
Ford F-150 Lightning Leveled Avalanche Lightning (Eibach Stage 1 & 35" Wild Peaks) IMG_9819
Ford F-150 Lightning Leveled Avalanche Lightning (Eibach Stage 1 & 35" Wild Peaks) IMG_9815
Ford F-150 Lightning Leveled Avalanche Lightning (Eibach Stage 1 & 35" Wild Peaks) IMG_9818
digitaldad
digitaldad
ABQ
2023 Lariat ER MaxTow
@digitaldad
Very nice - those UCAs look sharp! So cool you could garage install that, wish I could.
I was driving home all day today...really wish the range/efficiency hit wasn't as bad as it is, but really dig the truck in its current form.
95% home charging & local driving offsets it.
AZT9
Peoria, AZ
For better or worse I’ve gotten used to the hit. I leveled the truck on BFG ATs right after I bought it so I’m not accustomed to the “stock” range potential. 🫠
digitaldad
digitaldad
ABQ
How is the ride now compared to then?
AZT9
Peoria, AZ
Best I can describe is firm but much more compliant. Not so bouncy. Like I feel dips but no more bounce afterwards
digitaldad
digitaldad
ABQ
I completed half of my first road trip since the lift & tires were installed. 1.7 kWh average on the way out to visit family: 570 miles @ 70 MPH (speed limit was mostly 75).
I would have rather driven faster and charged more but am limited by charger availability/distance on this route.
This same stretch (reverse path - back in January & during a cold snap) when I bought the truck, was about 1.6 kWh, going 65 MPH (stock).
Replying to my own post for total/return info:
Drove some limited gaps @ 75 MPH and also experienced about 100 miles of strong head/cross wind near Amarillo...but still 70 MPH for most part.
Total roundtrip was 1.6 kWh on trip report. $371 bucks for charging on a 1,200 mile journey (ouch).
WXman
Central Kentucky
www.facebook.com
2025 F-150 Lightning Flash
Meteorology/Transportation
@digitaldad The Falken A/T4W is a bit heavy, which hits accel/braking/and "fuel economy" pretty hard. But they are excellent tires. We've reviewed several sets of the A/T3W on my channel and just finished up the last set of 295/70R18s at 80k miles. That's right, eighty thousand miles. Just fantastic for an all-terrain tire. And the A/T4W appears that it will be just as good. Put 20k miles on a set of those in 35x12.50R18 on a F-250 diesel and they only wore 3/32nds during that time. They were on pace for some seriously impressive mileage too, but I traded that truck for this Lightning.
Now I've been looking at a setup for this truck, and it's funny that your build is nearly identical to what I've been shopping. :)
digitaldad
digitaldad
ABQ
Don't I know it! Yeah, was aware up front of the weight adds of this tire/wheel combo, compared to stock. Those are impressive mileage numbers, thanks for sharing that.
digitaldad
digitaldad
ABQ
Continuing my approach to go furthest away from "optimal range", I attempted some 1.5" wheel spacers on my ride.
Was short lived.
The poke looked awesome (sorry, didnt take any pics), but I could not trim enough in the front to keep it: removed front tusks/crash bars, trimmed lower edge of metal bumper, cut some of the rear well carpet (little lip that hangs the lowest), and an edge of the hard plastic lip/clip where the bottom crease starts.
I think if I had attempted adding a front puck to the coilovers, it may have worked...but for now, simply removed the spacers.
I can say for sure now, I have absolutely no rub/odd sounds at any angles on the truck when turning far left/right.
Was short lived.
I would be extremely hesitant to run spacers on a 7,000lb truck with 775 ft lb of torque and only six lugs.....
HI Zeus
Craig
New Mexico / Hawaii
2023 Lightning XLT, 2013 Kia Optima Hybrid, 2003 F350, 1989-93 BMW Paris Dakars
SO retired!
I initially had the same concerns.
The last experience I had with spacers was a plate that went between the wheel and axle face (decades ago). Good modern spacers bolt on to the axle just like the wheel, and then the wheel bolts to them as per usual. In other words the only extra "risk" would be equivalent to adding 4 more wheels. If you can manage to keep your wheels bolted on, you can put spacers with no extra concern (once you recheck the torque after the original seating time period).
Yes, they will stress the wheel bearings etc. a bit more by having more leverage, but no more than a wheel with the equivalent spacing.
Unfortunately it is not "just" the same. Specifically you are adding another joint between the drive surface (the wheel hub) and the wheel. Normally there is only the brake rotor between the wheel and the hub, meaning power is transmitted from the hub to the wheel with only the rotor between. Now power is transmitted from the hub to the spacer, through the spacer itself, and then into studs of the spacer into the wheel. A wheel with different offset only changes the leverage on the ball joints and bearings, this changes some of how the drive force is transfered AND changes the stress on the studs, bearings, and ballpoint.
You also have to consider that there are now twice as many wheel studs to worry about for each wheel. Breaking a stud is rare, but not unheard of.
I'm not saying it cant be done, but the stresses here are worse than 3/4 ton trucks running spacers. Anyone who runs spacers should be VERY VERY worried about the quality of those spacers. Personally I dont think Aluminum spacers should be run at all even
