- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 F-150 LIGHTNING, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
Yes it does.Owners manual describes this very thing happening. "Prolonged use of this mode can cause the 12v battery to run out of charge"
It just doesn't tell the whole story, about the details, some of which are unexpected.
Like if the truck is OFF, it is still using a heavy 12V load in temp neutral mode and will drain the LVB because the HVB to LVB is disabled.
And that the fail-safe HVB to LVB transfer at below 30% won't happen during the time the truck is OFF and in temp neutral mode.
It also does not say that if the truck is in temp neutral mode but is ON, the 12v battery will be kept charged and not drained, which seems to be the case.
But now we know.
