Return to Sport not returning
RSMLightning25
Richard
Schertz, TX
2018 Lariat F-150 5.0 Ruby Red, 2025 Lariat Lightning Anti-Matter Blue
Network Security
I have also noticed this. It will ask me to return and select yes. It'll stay in sport for about 10 seconds, at least the gauges seem to indicate and then it the gauges change to normal. Looking forward to an update to fix this.
chriserx
Louisiana
I had an interesting interaction this morning...On startup it asked if I wanted to remain in sport, I nearly immediately selected yes, the prompt disappears, less than a second later, it asks again, select yes again, and it stayed in sport.
RLXXI
3rd rock
Automotive Technician
Same issue here and I'd also add the other day when I remote started and got in the truck 5 or so mins later, foot on brake, press start, got the prompt asking to stay in sport mode, selected yes then I brought up the screen with modes and confirmed it was on sport and then about 1-2 secs later I watched it change to normal mode on it's own.
If they would just set default to last user setting it would cure the nonsense of switching.
AMG
Aaron
2025 F-150 Lightning Lariat
Y'all, Ford absolutely knows about this. I reported it right when the update came out via Early Access Program. Then Ford responded to me via email and they even state they are working on the fix.
chriserx
Louisiana
There's no doubt about that, but details matter such as the timing of the reversion and in my situation yesterday where it asked me twice help pinpoint the logic fail. Also, they just don't want you to use sport so there are fewer warranty claims, at least that's the theory I will be promoting.
Timeless Epoch
Chad
2024 F150 Lightning Platinum
Professionally: Disaster Recovery - Recreationally: Watchmaker
Hey Brian @Ford Motor Company, I hope Ford doesn’t back burner or forget this fix as they shift focus to their EREV.
I don’t know if it’s related, but when this bug showed up with the previous update, I also started getting random ā€œdingsā€ occasionally on start up with no message. Similar to the one where you look away too long with BC or when entering a school zone. I’ll describe it as a ā€œbong bongā€.
AMG
Aaron
FYI I have this case open w ford on it. Did it like the day or two after I got the update via the early access program. They stated engineers r working on it weeks ago. Maybe they are.
CXH-06301636-C5F2P4 1FT6W5L77SWG07530
footballfalex
Alex
F150 Lightning 2024
It makes you even wonder what the point of the EAP program is because I've seen multiple people say they reported it and yet they still released it to the masses...
Reactions: AMG
chriserx
Louisiana
I haven't figured out the timing or number of presses, if anything, but at least 3 times now I've cycled between yes and no for a bit before stopping on yes and it stayed in sport if anyone wants to help figure it out šŸ˜‚
morrisosu
Shane
F150 Lightning Lariat ER
I’ll have to try this! :)
My return to sport pop-up worked this morning, I had used it yesterday afternoon to enhance my regen-braking performance, it was diminished in normal drive mode which I attributed to the HVB being at at optimized 100% SOC.
chriserx
Louisiana
Funnily enough, when I posted that my return to sport worked, right? Then the next long rest of the truck (after work) I got no popup and it went straight to normal....Crazy......
Ford Motor Company
Official Ford Account
F-150 Lightning
Team is working on the fix for this. I'll update y'all when I have more info.
