New 12v Charging Behavior Today
Kansan
Wayne
2024 Flash
Civil Engineer
Captured this behavior with my Bluetooth battery monitor today. My truck is not plugged in, it’s locked and the key fobs are in faraday pouches a long distance from the truck. The HVB is sitting at 77% and the truck is sitting in my heated garage.
The 12v battery was at a reasonable SOC. For some reason the truck decided to add energy to the 12v battery.
Ford F-150 Lightning New 12v Charging Behavior Today IMG_1426
PrimeRisk
Denver-Metro
Technonerd
What battery monitor are you using?
Your LVB state of charge probably dropped to the trigger point to activate a maintenance cycle.
Kansan
Wayne
2024 Flash
Civil Engineer
The picture shows that the voltage before the charge was 12.73v. That seems way too high to trigger a 12v boost.
Reactions: dww
Did you happen to trigger any functions on the Ford App around that time frame, ie. Location update, lock request ? These activities might have been a trigger.
Kansan
Wayne
2024 Flash
Civil Engineer
I was asleep when it occurred. I’m the only person with access.
mr.Magoo
2022 Lariat ER, AMB
Departure time? SW update ?
12.7 is basically/almost fully charged so I dont think it was a "energy transfer" per se. Do you have the shunt installed as well so you can see the current ?
Interesting behavior.
Maybe they put a better BMS program in the newer trucks - 24 Flash - to keep the 12v healthy.
That graph looks like a short charge voltage was applied of about 1/2 hour?
So the threshold looks to be around 12.7 volts, which could be about 90%.
12.8 volts to 13 volts is typical for full battery at rest after charging.
There are small parasitic drains on the battery when the truck is OFF.
If there was an OTA coming in, that might trigger a charge cycle if Ford has gotten their act together, people have been suggesting that for a long time. Some OTAs require 85-95% SOC to install.
Wonder what is going on?
Kansan
Wayne
2024 Flash
Civil Engineer
I just checked. I have departure times turned off. I can’t find any evidence of an update.
This is definitely new behavior on my 24 Flash. In November I left it unplugged in my garage for a week and the 12v drained down from 12.83v to 12.43v - there were no charging/boost events. Based on voltage drops it looks like I checked the app 3 times.
I’d love to think that Ford has sent an update that improves 12v charge maintenance.
Yes so would I and lots of others no doubt!
Unplugged truck, no trickle charger maintainer, no OTA, no other even that would turn the truck on...I am at as loss to think of anything...assuming the voltage reading from your monitor is accurate, a real mystery.
Maybe REM was playing on the SYNC4?
mr.Magoo
2022 Lariat ER, AMB
Ford F-150 Lightning New 12v Charging Behavior Today 1769220215389-i1
So no sooner did I post that my LVB had been fine for almost 2 years, did I start to see some odd behaviour on my LVB.
Many times would it reach 90%-ish SoC and just level out there, no charge current, no nothing.
But - the problem is that if the battery have entered a floating stage the voltage is supposed to be lower than the charging state (like 13.5-14 ish vs. 15) but as you can see, the Lightning keeps it at 15-15.2 even though the battery is no longer accepting charge and this for hours on end (which is not good).
I reset the BMS this morning hoping it'll fix things and nothing really happend right away except that battery age goes to 0-days. 7hrs later (lunch time) and the battery is reported to have 100% SoC.
We'll see how it holds up, when I checked battery voltages "offline" they seemed OK,
like 12.6-12.8 resting which would be essentially 100% SoC, yet the truck thought that meant 85% or whatever... so whomever programmed the algo for the BMS seem to have some homework.
Kansan
Wayne
2024 Flash
Civil Engineer
My observations lead me to believe that:
- The BMS can throttle charge rate regardless of DC supply voltage. Where are you measuring voltage?
- For at least a day after the reset the BMS is running a calibration routine where it’s determining the capacity and characteristics of the new battery. During that time the SOC will vary in ways that look strange otherwise. Check out this voltage curve - I had reset the BMS the prior afternoon.
- The 12v BMS is managing the SOC and charge rate based on the size and age of the battery as well as temperature. The behavior you describe is not unusual based on what I’ve seen on my truck.
Ford F-150 Lightning New 12v Charging Behavior Today IMG_1668
