12 volt Lithium Battery vs. 12 volt Lead Acid Battery
bc1
McPherson, KS
Hello guys. Thought I'd ask here since we have some battery experts in house. Looks like the 12 volt auxiliary battery on my 2013 Prius has crapped out with the low temperatures. In looking for a replacement I see where they sell what they call a Lithium 12 volt battery. Just wondering what anyone thought of these?
I don't know how old my battery is but don't remember replacing it in the last 5 or 6 years. I've bot the Yellow top Optima for our prior 2008 Prius one time. I'd probably have to order the Lithium online unless someone locally has it but its numbers are a lot better. On the other hand I plan to sell the Prius as soon as I put new brakes on it and clean it up whenever it warms up and I have time which has been the plan for over 3 months now. Thanks.
K6CCC
Glendora, Calif.
In that case, buy the cheapest battery that will work. No point in putting in an expensive battery into a vehicle you are selling in a few months.
Tom Jensen
Arlington, Virginia
F-150 Lightning 2023
Attorney
Lithium 12 volt batteries are great, very light and compact compared to any variety of lead acid battery. But they’re an investment. I use Dakota Lithium batteries for boats and back-up power and love them. But they’re a premium product for the time being.
Rtashiro
Ryan
Winnipeg, MB, Canada
Are there any 12 volt lithium equivalents that anyone has used in the lightning?
Mach Turtle
Central California
2021 Mach E, 2024 XLT
Bum
There are threads such as the following:
https://www.f150lightningforum.com/forum/threads/ohmmu-na-ion-do-not-buy.34022/
Some folks like 'em, others don't.
I personally prefer to keep the AGM battery rather than spending a bunch on something more expensive and potentially troublesome to lighten the vehicle by around half a percent. However, AGMs aren't without their problems too, and for some uses lithium 12V probably makes sense.
I wonder if anyone has tried possible NiMH options?
Did you replace your 12v with an Ohmmu ?
The Weatherman
Dean
South Central KY
I replaced my original battery with an OHMMU a couple of months ago.
I have been totally satisfied so far.
It was about $150 more than a comparable AGM.
mr.Magoo
2022 Lariat ER, AMB
So, I've been sceptical about Ohmmu for a while, primarily because people are "too happy" about it, and everytime there's something negative said about it it's the same people is coming to it's rescue / defences - why ? - I mean, if it works for you, great, but why do you feel the need to defend a company that you're not affilliated with, time and time again ?
Early versions were garbage:
Supposedly they've addressed a lot of the issues, but I just watched the "How Ohmmus are built video" and....
How are they built:
The modules appear to be these:
https://www.lifepo4-battery.com/Products/LiFePO4-Battery-Cell/gotion-40ah-lifepo4-battery-cell.html
The BMS is this:
https://jiabaida-bms.com/products/j...-or-switch-function-support-series-connection
One thing that stands out is that while they're talking about the heater, it seems like they're putting the temperature sensor on the heating element itself which seems pretty darn dumb.
And why is the element at the end and not between the cells / modules.
So, my personal opinion remains, Ohmmu (lithium based) might work in warm(non freezing climates) but I would stay away from them if you live in colder climates.
Ford F-150 Lightning 12 volt Lithium Battery vs. 12 volt Lead Acid Battery 1770506981383-3r
bc1
McPherson, KS
Quincy, Waldo hasn't had a chance to go through the videos but what is it exactly that cold climates would do to the battery and what about Kansas, in your opinion, which is in the middle of the climates? Just wondering what to do or avoid during the winter. Do they take the high heat better than lead acid? Thanks for your expertise.
mr.Magoo
2022 Lariat ER, AMB
As for your Prius I agree with everyone else, just get the cheapest battery that's of the same type/size as the one you have right now.
As for the rest....
I'm by no means an expert, all I know is that charging Lithium batteries in cold weather is a big no-no as it can result in lithium plating and will essentially destroy the battery.
So, some manufacturers put a temp sensor on the battery to prevent it from being charged when it's cold out, great, the battery won't be damaged, but it won't charge either, so eventually you'll run out of juice. (This is what Ohmmu did early on)
The next upgrade is to put a heater in/on the battery.
In the Lightning they heat the coolant/fluid that circulates through the pack so the packs are evenly heated (and cooled).
In the case of Ohmmu it looks like they slapped a resistive element on the end, which is bad to begin with as it won't heat it evenly, maybe, just maybe, do they have heating elements on all four sides and inbetween the cells, and in that case I suppose it isn't so bad, but I'm kind of sceptical that they do.
What's worse is that it looks like they placed the temp-probe onto the heater itself, so the sensor will heat up much faster than the actual pack, enabling charging too soon / when the pack is still cold.
This video shows the issue (it's not an Ohmmu battery by the looks of things, but the construction is similar).
The Weatherman
Dean
South Central KY
How are they built:
The BMS is this:
Somebody with first hand experience has to counter negative BS being spouted.
Unless you have first hand knowledge, I’ld suggest you be skeptical of the AI and YouTube posts. A lot of that is all about the clicks.
chriserx
Louisiana
Lifepo have a size/capacity advantage as well as (assuming that it's used in correct operating temp range) lifespan advantage.
Like most/all? batteries they have a capacity loss in the cold, but iirc the curve is steeper for a lifepo. In the cold the battery's internal resistance increases. Cold discharges can slightly lessen the lifespan of the especially at high draw rates which is why the truck will limit HVB draw rates (motor power gauge) in a cold, non preconditioned, unplugged truck.
The real issue for a lifepo battery is charging in the cold. When the battery is sufficiently cold, the lithium is able to plate onto the anode similar to how gold plating works. Resistance permanently increases, increasing heat, lowering capacity, dendrites form (kinda like stalactites of lithium metal), once that initial one forms, it's growth accelerates, at some point it can grow large enough to pierce the separator in the battery and at best you get a failed cell, at worst an explosion. In a lifepo it's more likely a fire but still.
DavidS
DAVID
Green Bay, WI
F150 Lightning Lariat
Just one more point of reference. Optima has probably been selling lithium 12v car batteries longer than anyone and premium agm batteries for even longer, and while they are willing to sell you a range of batteries for your ICE 150, they don’t recommend any of their products for the EV Lightning.
mr.Magoo
2022 Lariat ER, AMB
So since you have first hand experience, by all means, please DO enlighten us morons as to how the battery is designed, where their heating elements and temperature sensors are placed.
I'm only going by what Ohmmu shows in their own video.
