- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 F-150 LIGHTNING, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
A L2 EVSE charger, which means the Lightning DC-DC converter was charging the Ohmmu at the time it exploded/caught fire.It had a charger attached and still attached to the truck so it may have been being charged by both.
That extent of my knowledge of the situation.
If it was using a high charging current, like others have measured, it could very well have caused the problem - high charging currents CAN cause batteries to explode.
The guy in the reddit post would have done better to leave the Ohmmu on the trickle battery maintainer with a low current that should not result in an explosion.
So I agree with you that the battery was being "force charged" but the problem is that is the norm with the Lightning when the 12v battery gets low, as others have posted.
This is yet another reason mine is staying on a battery maintainer - even AGM batteries can swell and explode if subjected to high charging currents!
