NeighborGeek
Steve
2025 F150 Lightning Flash
I have a 2025 Flash, Job 2 (May '25 build date), and I'm trying to find out if there is a way to enable the Approach Detection/Lighting feature (i.e., puddle lights, etc., that come on as you walk up to the truck). It is listed as a "feature" on Ford's listing of changes for Job 2 (other changes include dropping the tailgate step, phone charger, etc. all of which my truck "has".) But I have no approach lights.
That shouldn't require forscan, it's just a setting in the infotainment system. According to the owner's manual, press
Vehicle> Lighting > toggle Welcome Lighting on
Dahveed
Salina, Kansas
2025 Ford F-150 Lightning Flash
It's not present in the lighting options on my '25 job 2 Flash.
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
Are welcome lights when you approach the car, or when you unlock it?
Dahveed
Salina, Kansas
When you approach. It should detect a nearby fob and turn on all of the exterior lightning as if you had pressed the unlock button on the fob.
hb.sagen
Henning
Norway
Nice to know, my property isn’t big enough for an American truck, as the lights come on, even when the fob or phone isn’t with me.
I believed it was a deterrent function :p
Dahveed
Salina, Kansas
astrand1
Alex
Studio truck driver
I reviewed the following post: DIY: Installing Passive Entry To A 2022 F-150 Lightning XLT | Ford Lightning Forum For F-150 Lightning EV Pickup: News, Owners, Discussions, Community
I played around a bit and was able to enable Approach/Welcome Lighting on my Flash. In the BdyCM easy mode, I enabled all of the Approach Detection options and set BdyCM 726-45-01 to xxxx xxxx x1--. The toggle is still not present in the Lighting menu, but the feature is functional.
There should be a setting in the APIM to enable the toggle. That’s probably all you’re missing.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
Maybe check this setting.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 IMG_0846
Kenstjohn
Ken
Tacoma, Washington
2025 F-150 Lightning Flash, 2022 Lincoln Corsair GT (PHEV)
Retired USAF, Retired IT Managment Company Owner
Sorry, have to ask - you have Welcome Lighting turned on in Sync settings, right?
What FORScan mods have you done already (specifically the Lincoln Folding mirrors)?
As others implied, that option is not listed.
Ken
Kenstjohn
Ken
Tacoma, Washington
Thanks ... I'll give this a try!!
Amazing that y'all are smarter than the guys at a Ford dealership!!
Ken
That was it. I changed mine from xxx3 to xxx7 and now the Welcome Lighting toggle is available.
So this appears to be unique to Job 2 2025 Flash. I have a database of 100 Lightning As-Builts. Approach Lighting is enabled for 24-25 Flash except the 2025 Job 2 Flash with the 123 kWh battery (8th character of VIN is "U").
Enabled: 22-23 XLT 312A. all Lariat and Plat, 24-25 Flash w/131 kWh battery
Not enabled: All Pros and XLT 311A, 2025 Job 2 Flash.
P.S. Battery Size determination post here.
