powertrain malfunction with 100% power - Code P0DE9
Maxx
Maxx
Update: Got the call this morning from service advisor (3 days after Truck was done and ready). Picked it up this afternoon. It runs OK with no wrench. It cost Ford a little over $900.
They replaced the Coolant Diverter Valve and did pcm software update. They said, they retrieved code P0604 and made reference to TSB 25-2236 - PCM ABS, SOBDMB, SOBDNC, SOBDM, BECM. I don't understand any of this. All I know is that the wrench is off.
Next time it comes on, it most likely will be out of my pocket.
p.s. my battery health drop 0.5 to 97.5% while in the shop.
Edit: It is May 2026 now and my battery health is back up to 98.5%. When I look at some of scanner numbers, I feel like Ford may have released some of the reserved/protected part of my battery. If they have, it maybe because my SOC is usually between 40-60 and rarely outside 30-70.
Deleted member 12322
Guest
To your earlier question, I was getting the wrench every time my truck started. I didn’t actually have any perceptible issues driving. If not for the wrench I wouldn’t have guessed anything was wrong. I drove it with the wrench for about a month before I was settled in my new home and could make it to the dealer.
Maxx
Maxx
I didn't notice anything abnormal either. I am thinking when the battery is cold during charging, especially fast charging heating it up may reduce long term damage. Also during a drive with cold battery, I may not get as much energy out of it so heating it may give me more energy out than I put in warming it up. I don't have any data. Just guessing here. So if the valve can not help heating the battery properly when it is cold, damage may be more long term.
I recorded some data when I dropped it off. I may try to record some data after the fix in similar ambient and battery temp and see if battery heats up any faster. Here is the before data. It went up 5 degrees in 25 minutes driving 70+ mph.
Ford F-150 Lightning powertrain malfunction with 100% power - Code P0DE9 Screenshot_20251028_205003
johnnyonetime
FL
2022 Lariat ER
Has anyone have had coolant diverted valve replaced but didn’t have clicking sound coming out of it. I don’t hear any clicks and my shifter acts OK too. What else can it be?
I noticed clicking sounds 3 weeks ago along with the schedule service soon message. I suspect diverter valve failure also, 73k miles on my ‘22 ER. Earliest available appointment is Monday, made 3 weeks ago. In the meantime I bought the valve online, hoping that’s the issue and they can turn it around same day.
Maxx
Maxx
You are doing better than I did at 20K. Good luck.
johnnyonetime
FL
2022 Lariat ER
FDRS confirmed diverter valve failure. I bought the correct part. Quoted 5 hours and $900.
Not thrilled with the price but still cheaper than the extended warranty in Florida.
Thanks to Mullinax Ford in New Smyrna Beach for getting it done today. Heading to San Antonio in the morning.
jbassett
Justin
Western New York
2023 Lightning Lariat SR
Software Engineer
I got this code too. I give the dealership the code hoping to avoid the diagnostic fee, that didn't work, and I charged $200 for them to tell me what I already knew. But the part they could have told me first was that I was a single month out of date for the 3 year warranty.... Hoping that @Ford Motor Company might help me out and show me mercy. The $1,500 quote hurt my soul.
Eastbaylightning
Antz Tony
Walnut Creek, California
F150 Lightning Pro
I had my HV coolant diverter valve replacement around 40K miles. No error but heard the clicking after I turned off the power. Quite an expensive replacement.
Maxx
Maxx
It seems like dealers charge like doctors do. $900 for Ford but $1500 for the customer is messed up.
This is obviously a design flaw and should be covered after warranty. The sad thing is that, the new part is the same as the old one and is likely to break again.
Eastbaylightning
Antz Tony
F150 Lightning Pro
I agree this should be covered under the warranty. When I brought it to Ford dealer to inspect, they determined this part was about to fail, and since it's High Voltage related, I couldn't take my truck back for safety reason. I argued, if it is for safety reason and HV related issue, then it should be covered under the HV battery system warranty. My truck ended up stuck in the dealer for 1+ week for repair.
Maxx
Maxx
I have had cases in the past that dealer (not Ford) refused to cover something that was clearly a warranty issue. Not sure just because it was inconvenient for them to deal with manufacturer or because they could charge me more. That is why my satisfaction with any car is inversely related to the number of my dealer visits (including purchase).
jbassett
Justin
Western New York
Software Engineer
Part arrived today and it took me an hour to replace. Code cleared itself after. So tell me, why was my quote for the repair $1,500? Is the labor rate $1,300 an hour at the dealership? Dealerships wonder why people don't like them, this is why!
Maxx
Maxx
Thanks for sharing. It is great news that you were able to do it yourself. Did You have to do anything challenging to take the bubbles out of cooling system? Any advice for anyone that has never done this before but is brave/stupid enough to try? I expect to have this problem again.
jbassett
Justin
Western New York
Software Engineer
With as little coolant as I lost I'm not worried. It looked to be less than 1/2 a cup of coolant in the valve. I'm going to watch the reservoir, but I'm pretty confident that the small bubble will work itself out.
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
What did the part cost?
