powertrain malfunction with 100% power - Code P0DE9
Ford Motor Company
Official Ford Account
F-150 Lightning
After raving about how flawless my ride has been, today I got the wrench. I read some of the related threads where people had bad modules and shifter issues but I still can't tell which group of unfortune owners I belong to. Here is the short story;
I left the driveway in rain and 4 minutes later I got the wrench but my power was at 100%. Dropped to 95% later at night. I tried the wistful thinking thing (turned off the power and back on twice). The wrench went away. I plugged in for a minute to see if it charges OK. It seemed fine. Got back on the road and wrench came back in less than 3 minutes. I checked the voltage variation with carscanner and it didn't look too bad. I ran the trouble codes (attached) and I have no idea what I am looking at or should be looking at.
Background: At 10K service and recall visit, service advisor told me the mechanic said your battery is borderliner. I assume one of the cells may have been high or low but not bad enough.
I have been almost exclusively Level 2 charging but a few weeks ago I had 6 DCFC in one week.
I tried to charge the truck for just a minute and it charged OK. It drives fine too.
Did any of you have similar symptoms? Is it a battery module? Shifter? Something does not like the moisture? A bad sensor?…. any ideas?
Sorry to not provide anything groundbreaking here, but suggest taking it to your dealer. If you send me some details via DM (VIN, dealership, etc.) I will flag it with our engineering team so they can support the dealer as needed. We'll get you sorted!
Maxx
Maxx
I saw your message right after I DMed you. Thanks for reaching out.
Does that mean if this part has a design flaw, it has not been fixed? In other words, if they fixed it, would it have a different part number in 25 than it did in 23?
I have an appointment in a week. After it is done, I will post the results to confirm what he problem was.
I'm not aware of any revisions to the design/build/materials from the original part, but they will alter the PN if they do. Those which have failed might be 1 in a million defects and the vast majority of gears are suitable for long life service ..... OR NOT.....
Maxx
Maxx
I keep my fingers crossed that is indeed the case and as my mama told me I am just that special.
Maxx
Maxx
Has anyone have had coolant diverted valve replaced but didn’t have clicking sound coming out of it. I don’t hear any clicks and my shifter acts OK too. What else can it be?
There have been a few reports of the valve being replaced, but I don't recall if they heard clicking, hopefully they find this thread and comment about what lead up to the replacement.
Maxx
Maxx
Update: Truck is in the shop and they said they are replacing the coolant diverting valve. This is after I told them that is what I suspect. I just hope it is a conclusion they came up on their own because unlike others, I never heard any noise coming from the valve.
The other tidbit is that when they were working on it, I got a message on Ford pass “Pro Power Onboard service needed”. Is this something I need to worry about or them updating software or disconnecting 12V battery could cause that message?
flyct
Jerry
South Florida
Blissfully Retired
I got the exact same message when they were manually applying a software patch when the mobile rep was working on my truck in my driveway.
Maxx
Maxx
Did you happen to check your AC outputs after to make sure everything worked OK?
flyct
Jerry
South Florida
Blissfully Retired
Yes, Everything is working fine after the fault was gone.
Deleted member 12322
Guest
I had my coolant valve replaced a few months ago. It started giving me issues right before I moved across the country. I had no problems fast charging or driving the roughly 2,500 miles I needed to go. I didn’t notice any sounds or clicking. My dealer diagnosed it, ordered the part while I kept my truck, and it took a few hours for them to replace it (it was their first ever replacement).
Not a huge deal in my opinion but also not great that it failed within 35,000 miles. In comparable years of ownership I have had more trips to the dealer for my Lightning than my previous Ranger. Still like the truck but there are certainly some weak spots.
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
I had to go looking to find the other thread on this diverter valve - seemed that the Heat Pump equiped truck didn't use it.
here
The photos RL XXI posted at #50 indicated no diverter valve.
In the 22-23 trucks there are two valves, I think the 24+ trucks have only one, it's buried down deep near the AC compressor. The heat pump trucks still need to manage coolant flow going to the traction battery through the chiller or the heat exchanger or even the PTC which I think is still on HP trucks but it's only used in extreme cold conditions to boost heating to the battery pack when needed.
RLXXI
3rd rock
Automotive Technician
I've recently discovered there are 2 diverter valves on the 25. One behind an under shield the other under the frunk tub. Pictured is the one under the shield.
Ford F-150 Lightning powertrain malfunction with 100% power - Code P0DE9 2025coolantdivertervalv
