Ajzride
You select OP Long in the Comma settings by toggling on "experimental mode" in the Comma, then toggling on "OpenPilot Longitudinal Control". Different versions of OP/BP/SP have similar but slightly different locations in the Comma settings. Now when you activate your cruise control, the ACC portion is controlled by Comma, not the Ford.
Slight correction here:
You first tun on "OpenPilot Longitudinal Control" or "Alpha Long" (it depends on whether you are doing on your device or in sunnylink what the name is. I have a request to make the name consistent between the two). This gives comma control of the gas and brake, and it will operate like standard ACC. You can then turn on experimental mode, which adds stop signs and red light functionality (that works about 50% of the time).
