Kansan
Wayne
2024 Flash
Civil Engineer
He had to enter a pin....? I wonder what that was about? I still have that ACM update in my list. I just ignore it now. But on the other hand my truck does not have an outstanding recall for the ACM module anyway (24U14). Just a ACM module in my list of available software that won't go away.
I had mobile service come out twice this week, once for my Lightning updates and once for my 23 Lariat 5.0. Both have had the persistent ACM update that won’t clear. The Lightning had an ACM recall and the 5.0 didn’t have an ACM recall.
I stood and talked to the guys that did the updates. On the recalls - ACM, trailer module and parking pawl there was a validation process at the end of the update where the tech had to copy some data from the recall description in FDRS and upload it. I saw them do 4 recall updates and one of the guys briefly explained but I didn’t watch close enough to be able to repeat it myself.
The ACM update that had an associated recall cleared from the update list. The ACM update without a recall did not clear for the dealer tech either.
My dealer mentioned the same thing about validation they had to send in. Said it could take a month for recall to clear from my account.
Seems to me FDRS knows what software was successfully installed and that should be Ford’s validation source. Can understand dealer frustration with Ford at times.
Mike G
Mike G
N. AL, USA
FDRS does update the cloud server when an update is performed. The tech likely ran the verification after doing the updates and copied the code it provided into the verification form in PTS.
It doesn't take a month. It takes seconds to clear the recall...what makes the process take longer on some recalls is if the dealer's warranty service person takes a while to enter the info or if for some reason additional info is required (like picture verification in the case of the lightbar) to process the verification.
Mike G
Mike G
N. AL, USA
Came across this today:
Ford F-150 Lightning Lightning Software Updates using FDRS SSM_54668_BC_OTA
Mike G
Mike G
N. AL, USA
Similar to the message I got when I asked about getting the update to activate Walk Away Locks.
Well that's not actually the problem with WAL programming right now....the actual problem (aside from the fact that your dealership doesn't want to do the update for free) is the fact that the ability to perform a BCM software update (or PMI) has been removed from the FDRS tool the techs use because of concerns that it could end up bricking the BCM module. They are doing testing and will turn the ability back on in FDRS (by model year) when it's once again safe to perform updates or PMIs. And if they can't do an update using the FDRS tool, they won't even attempt to send your truck an update via OTA, since that's even riskier.
Mike G
Mike G
N. AL, USA
...and your sig says you have a '23 model? You should already have had WAL. Only early build '22 models (like up to June of 2022) needed the BCM and APIM update to enable WAL. I'm wondering where things went wrong on your truck. It's possible that the BCM has the correct software but the WAL button to turn it on and off isn't showing up in your Sync screen (that's the APIM update part of the equation). If that's the case it would take about 5 minutes with FORScan to turn that on...it's even listed in the 'easy mode' menu and doesn't require you to do any 'hex' editing.
PJnc284
Garner, NC
23s needed the bcm update as well. Got the dealer to update mine while in for the battery sensor replacement a while back. 24+ came with it from the factory.
Lake Placid Lightning
2023 Lariat SR w/510A
Civil Engineer
Actually, it is the opposite. I added the WAL toggle via FORScan but haven't got the BCM update. I updated my '23 truck in May 2025 via FDRS, but wasn't able to update the BCM due to the password required.
21st Century Truck
Martin
FYI I've had success with these locked BCM issues by going to my good local dealer and asking for the BCM dealer update (just the BCM) because I can't perform it myself anymore, and that it therefore falls under warranty action. When put that way, the Service people do the BMS update for me for free and absorb the usual 20 minute time cost (when using their fast VMS dongle).
Good Luck!
Seriously......how difficult would it be to add a service procedure to FDRS for the IPMA to write the config that enables the features? FORScan ftw.
astrand1
Alex
Studio truck driver
And that’s why having smart people here and forscan is such a great help.
SFsparkie
2023 F150 Lightning Lariat ER 01/23
Looking for the opportunity to observe a San Francisco Bay Area Lightning owner update their own vehicle using FDRS. I am an old man with a 23 Lariat experienced in following members directions for all the FORScan modifications. Now that I am beyond the 3 year warranty FDRS updates are on me. I am not asking someone to risk modifying my vehicle. Just a show and tell before I set out on my own installing updates and updating my asbuilt at my risk. Thanks in advance.
astrand1
Alex
Studio truck driver
Well just to clear any misinformation for others. Warranty or not you were always on the hook for updates via FDRS. The only way Ford would cover such things is if they could tie it to a warranty claim. They will not just do updates unless they can get paid. Having said that if you have a really good relationship with your dealer “maybe” they could do something for you but normally it’s not something they would just do.
