F-150 Lightning AC fully discharged at 40k miles – paid out of pocket, is this normal under Ford Protect?
designthis
NYS
2023 F150 Lightning Lariat SR Black 8/21/23 blend
Builder
2023 Ford F-150 Lightning Lariat, ~40,000 miles.
I recently started getting repeated “Powertrain Malfunction / Reduced Power” warnings along with no AC cooling (fan worked, no cold air). Took it to the dealer.
They diagnosed:
  • Code P0534 (refrigerant loss of charge)
  • System had zero pressure (completely empty)
  • Vacuum test passed, no leak found
  • Sniffer test found no leak
  • Recharged system to spec → AC now works, no warnings
They charged me ~$400 and said:
  • Refrigerant recharge is not covered under Ford Protect (PremiumCARE EV)
  • There was “nothing to submit” since no failed part was identified
  • If it leaks again and they can find the source, then the repair would be covered
A few questions for those with experience:
  1. Has anyone else had a fully discharged AC system on a Lightning around this mileage?
  2. Did Ford Protect cover anything in your case, or were you also out of pocket for the recharge?
  3. If the system was completely empty, did a leak eventually show up later?
  4. Any common failure points I should be watching (compressor, valves, condenser, etc.)?
I understand refrigerant isn’t typically covered, but it seems odd for a sealed system to be completely empty with no identifiable leak.
Appreciate any insight—just trying to understand if this is typical first-step diagnosis or something I should push harder on.
A sealed system doesn't empty unless it leaks. Therefore, they failed in their diagnosis.
designthis
NYS
Builder
Service manager said at 40,000 miles the dye doesn’t show up. My guess is that in order to check the entire system, you’d need to remove the chassis, but I’m unsure.
MotoGary
Gary
Utah
'23 Lightning XLT SR (Totaled), '24 F150 XLT 3.5L EB
New Home Construction/Sales
There's absolutely a leak! You should push back on this. Ask the Service Manager exactly how the refrigerant escaped without a leak. There are only two possibilities: 1. It wasn't filled at the factory or 2. The system isn't fully sealed. Since the AC worked at one time, the system must have been charged at the factory. That leaves a leak as the only real possibility.
AI suggests the following options:
1. Ask them to add UV dye and recharge. Drive for a few days/weeks then recheck for dye traces
2. Request a pressure test under operating conditions, not just static
3. If it happens again, push for evaporator inspection (common culprit, but labor-intensive)
designthis
NYS
Builder
Believe me, I pushed back. He said because no parts were replaced, it’s not broken—according to Ford Warranty—therefore I’m on-the-hook. As if the gas is *not* a part?
Incompetent service center, boycott and submit abrasive google reviews.
MotoGary
Gary
Utah
Clearly there's a leak and the fact that they weren't willing to do what it takes to find it shouldn't be your problem. If they want to take the easy way out, at the very least you shouldn't have to pay for the diagnostic labor since they didn't finish the job.
Adventureboy
Agree with this. In Canada, it is illegal to fill refrigerant without doing a full leak test. The refrigerant went somewhere.
My bar is this: 2005 Volvo purchased new, is 21 years old, and AC still blows cold, no leaks in 21 years.
NeighborGeek
Steve
2025 F150 Lightning Flash
I'm sure this part is accurate. If there is nothing wrong with the system, then the warranty won't cover adding refrigerant. The only way that could be the case though is if someone removed the refrigerant. Assuming you didn't remove the refrigerant, then there's a leak.
That's where the dealer failed you. It's not about getting the refrigerant covered, it's about finding the real problem. If they find and fix the leak, then the refrigerant may be covered along with replacement of the failed part.
jefrank
Fenton, Michigan
2022 Ford F-150 Lightning Lariat ER, 2004 BMW 330Ci
They diagnosed:
I've started experiencing the same symptoms and my code reader is indicating refrigerant discharge as well. My truck is at about 44k.
Not sure how the refrigerant can vanish without there being a leak.... did they even try to explain that?
designthis
NYS
Builder
That was exactly my reaction.
Dealer confirmed the system had zero pressure (completely empty) and threw P0534. They did a vacuum test, sniffer, etc. and couldn’t find a leak, then recharged it and everything works now.
Their explanation was basically:
“If there is a leak, it’s too small or conditional to detect right now.”
Which I get in theory, but like you said—refrigerant doesn’t just disappear. So either there is a slow/intermittent leak that hasn’t revealed itself yet, or it lost charge under some condition they can’t replicate in the shop
They also said if it leaks down again, that’s when it usually becomes diagnosable (UV dye shows up, etc.) and then it would be a covered repair.
Curious what you end up finding out. Please let me know!
Scorpio3d
SS/IBA car wash owner
I have not experienced this problem but I’m only at a little over 33,000. I will now be keeping a close eye on this.
Hopefully not another future recall!
So he’s saying the dye can read the miles on your truck?
sd25
NJ
2022 F-150 Lightning Lariat ER, Rivian R1T
I've had a couple of leaks in the AC system that cools the battery (Max Tow package) that were fixed while still under warranty. First one was on the high side port valve which was an easy fix.
Most recent one was very hard to find. Happened during a road trip and that dealer couldn't find the leak so they just refilled the system. Luckily I have a good local dealership and explaining the issue when I got home got them to keep looking.
They eventually found evidence of a leak (uv dye) near the compressor seal on the low side. They said the way the seal was pinched, it may have been there since delivery. Dealer had to drop the HV battery to access the compressor and replace the seal.
