Battery SOH - bragging rights or bullshit?
I've noticed between the Mach-E and Lightning forums a consistent fact - Lightning SOHs are considerably higher, or perfect, as compared to Mach-E SOHs. Is this because of:
1) Better battery technology on Lightnings as compared to Mach-Es?
2) Better BMS on Lightnings as compared to Mach-Es?
3) Different algorithm calculating SOH?
Thoughts?
RLXXI
3rd rock
Automotive Technician
Thoughts?
Isn't the mach e battery LFP as opposed to our NCM?
StevenC56
Steven
Fresno California
2024 Lightning Lariat Avalanche, 2017 Explorer Platinum
Not LFP on all years and models. Our 2025 GT has the 91kWh NCM battery.
I personally don't trust the SOH number. All I care about is my max useable energy when at 100% SOC (displayed).
I go with option 1 but modified:
1) Better Different battery technology on Lightnings as compared to Mach-Es?
After experiencing two failed modules, not sure the Lightning tech is better, just different. Son who lives with us has a Mach-E. Worse SOH, fewer miles, but lives outdoors while my Lightning is garaged.
Jseis
Washington
…that their GOM lies.
Every time I see ā€œGOMā€œ I think you youngins are a lost cause. Here’s what a ā€˜62 VW Beetle gave you for a GOM to roll down the highway on. I drove 56 miles on ā€œRā€ and gassed up to 10 gallons the next morning. It took real math & experience to use the gauge.
Ford F-150 Lightning Battery SOH - bragging rights or bullshit? IMG_0825
I had a 68. Interestingly, ā€œRā€ meant reserve. You supposedly had 1 gallon remaining between the extremes of the little horizontal tick mark.
At least that was the U.S. spiel. It was probably 4 liters or some other SI measurement.
Jseis
Washington
The weird thing is it’s a physical gauge with a float but on an apparent logarithmic scale (perhaps due to the tank being slightly narrower at top?). Iā€˜Ll never forget rolling into South Bend at 6:05 pm on a Friday night and the Shell station was closed. I drove the next 56 miles at 30 mph knowing that the Bug was good for nearly 40+ mpg at that speed. All I needed was 1.5 gallons. I got home an hour and a half later & told my Dad that.. don’t know if it’ll start in the morning. Well, it did and I high tailed it to the local gas station 1 mile west and filled it up with 10.0 gallons. LOL, it had been stone cold empty.
