Battery SOH - bragging rights or bullshit?
dmd3home
Dan
Central Coast CA
2023 Lightning Pro, 2014 Spark EV, 21 Tesla Y, 2018 BMW X5 phev
I had a 68. Interestingly, “R” meant reserve. You supposedly had 1 gallon remaining between the extremes of the little horizontal tick mark.
At least that was the U.S. spiel. It was probably 4 liters or some other SI measurement.
I had a '56 VW....no gas gauge at all! Had a "reserve" position on a foot lever that gave you 1 more gallon. You need to always remember to kick the lever back to normal when you fill up.....worked perfectly!
mr.Magoo
2022 Lariat ER, AMB
Why would the SoH number be bullshit?
It's not BS as such, but it is also not a standardized unit, it's a calculated number or a "guesstimate".
For all we know Ford doesn't even use the same algorithm/formula between the Lightning and the Mach-E.
So, it's a good indicator, but nothing to obsess about.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
I wonder if we might be misinterpreting what is being measured. Could SOH just be tracking whether balancing is required? We have reports of people seeing the SOH drop into the nineties and then later coming back to 100%. This implies that there must be some treatment available for poor health. There’s really no way to bring back lost capacity so a rising SOH wouldn’t make sense if it was directly related to capacity.
mr.Magoo
2022 Lariat ER, AMB
There's dedicated data points for module variation, for both voltage, state of charge and capacity. There's also an extended battery report that can be pulled via FDRS (and maybe PTS - don't remember).
So using SoH as your "outta whack" indicator seems a bit redundant.
But, it's a valid question...
With all these data points, what's the purpose of SoH in the first place.
Perhaps the engineers thought it'd be cool to show it on the cluster just like SoC and they did some magic formula to take all parameters into account, but the warranty department found out about it before they had a chance to implement it because they didn't want to deal with people requesting a full battery replacement after two years just because their SoH showed 99.9%
The calculated number may change and go up or down due to recalibration, but the real capacity will never actually go up.
The SOH is the present usable capacity divided by the present original capacity times 100%.
So if your battery began new as 98kWh and is now 90kWh that means it's SOH is approximately:
90 / 98 x 100 = 91.8% The capacity is the usable energy expressed as kWh.
Because the truck BMS SOH calculation involves measurements, for example coulombs and voltages by the BMS, there can be errors resulting in 'drift', and as the errors are corrected the SOH calculation will change.
Strictly speaking, the BMS can only estimate the SOC and the SOH because to get the actual numbers, the battery would have to be charged to it's maximum level and then discharged to zero while counting the total energy discharged.
Since we never take the battery to zero, the SOH is an estimate using one of a number of analytical methods, such as the Kalman filter method:
https://www.mathworks.com/help/simscape-battery/ref/batterycapacityestimatorkalmanfilter.html
I don't think Ford has disclosed what method is used in their BMS to estimate SOC or SOH, but I think we assume it is a coulomb counting method with some kind of correction mechanism for drift.
The coulomb counting estimates the SOC (state of charge) of the battery by measuring the current going into and out of the battery during charging and discharging and integrating it over time.
Coulomb counting can be combined with the Kalman filter method for better accuracy.
Balancing is passive and happens during charging.
It involves discharging the strongest cells with the highest voltage until they match the weakest cells so they can reach their maximum capacity.
Some current that goes into the battery will be discharged through internal resistances during that process, producing heat as 'wasted' energy.
That wasted energy has to be accounted for by the BMS in getting accurate SOC and SOH numbers. The Kalman filter method can be used to correct for this.
https://ieeexplore.ieee.org/document/10471421
As the battery ages, the maximum SOC as calculated by the coulomb method counting will decline, and so the will the calculation of SOH as a result.
Inaccuracies in meaurements will occur and lead to an inaccurate SOC and SOH.
When the BMS recalibrates to correct for these errors, the SOC and SOH will change, which is what has been observed.
That does not mean the battery has somehow 'healed' however, only that the calculation has been made more accurate (we hope).
Vancouver, Canada
2023 F150 Lightning Lariat ER
I am currently in the process of having one module replaced. Before it went into the shop Car Scanner was showing 100% for the battery state of health. So I don't think it reliably tells you anything about the health of the HVB.
I ended up having two modules replaced. I love the truck but IMO HVB SOH doesn't reliably tell you anything about the health of the HVB.
HVB SOC module variation is what told me that one or more modules were bad. The first image is when the truck went in for repair back then and the second is from last week.
Ford F-150 Lightning Battery SOH - bragging rights or bullshit? Bad
Ford F-150 Lightning Battery SOH - bragging rights or bullshit? Good
Ideally the SOH tells you something about battery capacity degradation.
But it does not tell you about bad modules failing unless and until there is a huge drop in SOH.
Other module failure indications should show up before the BMS tells you you SOH has dropped significantly.
One or a few bad cells in a module is not going to change the 'capacity' of the battery that much so the SOH will not show that the module is in trouble.
As noted above the voltage different especially under load is the indication to look for.
From my experience reading about the Leaf battery, the best way to get a sense of the battery's well-being (avoid calling it 'health') is to monitor the voltages and delta in a dynamic test, that is when driving and especially accelerating. That is when problems can't hide.
There are ways to spoof the battery scan readings senn with LeafSpy for example, or any scanner, which unscrupulous Leaf sellers know about, but they fail with an acceleration test.
StevenC56
Steven
Fresno California
2024 Lightning Lariat Avalanche, 2017 Explorer Platinum
How do you obtain this battery SOH information?
Fwiw, a short time after purchasing my 2023 (in Aug 24) the battery reported 97.5% SOH. After having my HV Contactor replaced it went up to 100% and has stayed there since.
abcut973
Anthony
Denham Springs
I had one module replaced back in February. My SOH before that was 98%. When i got the yellow wrench I remember having my SOH down to 86% with voltage and module variations out of wack as shown above. After replacement my SOH went to 90% but my variations were within specs. Since February I've been charging to 100% a couple times per month in order to recalibrate the BMS. My current SOH is at 93.5% now. Car is charging and driving fine. I have 131kw capacity at 100%. Some members are reporting that it takes a while for the BMS to adjust. So I will see how long it will take to get my SOH back to pre module failure if it ever do so.
halfbakedenchilada
2024 Lariat ER
My feeling is that it's probably not bullshit, in the sense that SoH is based on something real (or at least something estimated), but that, in general, EV drivers spend wayyy too much time thinking about it. What matters to me is the experience of driving it. I just got back from a ~2500 mile road trip where I hammered the crap out of it at DCFCs. I've got 30,000 miles on it, and the experience recently was no different than when it was new. What's my SoH? Who cares: my truck still handles days where I fast charge 7 times just fine, never thermally limited. The stops are the same length as they've always been, at least without measuring them with a stop watch.
I know OP wasn't asking about this in particular, but unless you have a problem I say forget it and drive, just like we used to do in our ICE cars.
Grease Lightning
Johnathan
Albany, Oregon USA
2023 F-150 Lightning XLT
I've noticed between the Mach-E and Lightning forums a consistent fact - Lightning SOHs are considerably higher, or perfect, as compared to Mach-E SOHs. Is this because of:
1) Better battery technology on Lightnings as compared to Mach-Es?
2) Better BMS on Lightnings as compared to Mach-Es?
3) Different algorithm calculating SOH?
Thoughts?
I will go your your title BS….
but in reality is I think they baked in the buffer to always make our SOH look close to 💯…..
Just looked at my 2023 Pro SR with CarScanner - 100% SOH and voltage variations was close to zero (0.001 or something even lower than @lightning-spark readings).
Fingers crossed!
