Tips for carrying 20 pound propane tanks in the bed?
lex-man
Alex
Upstate New York, Sarasota Florida
Ford Lighning Lariat
Okay. I admit this is a niche use case :)
I often have to carry 20 lb propane tanks to get them refilled for
My heaters and grill. I haven’t found d a good way to keep them from
Bouncing around in my bed. I have tried tension bars and bungee cords, but haven’t found the right solution yet.
Anyone have a good way to
Do this? Thank you !
Ratchet strapped to the bed side wall so they don't roll around.
saturnschildren
Glen
Peterborough, Ontario
www.glenhunter.ca
2022 Lightning Lariat XR, 1963 Lotus Elite, 1953 Unimog 401
I've found that one of the smaller sizes of the ubiquitous black bins can hold two side by side.
I carry a lot of gas/diesel cans around and I run a strap from one side of the bet to the other with the strap threaded though the handles and that does a good job of keeping them upright and from sliding around. I also have one of the ratchet bars to keep things from sliding to the front of the bed.
mb0220
Matt
2022 Lariat ER
Build yourself a crate out of 2x4s with square grids that exactly fit the propane tanks. Then you just need to strap the crate to your bed however you want.
MidAtlanticLightningClub
F-150 Lightning Lariat ER
You said "I often have to carry 20 lb propane tanks". Do you mean plural as in carrying multiple at a time? You can get a pallet for free and cut holes to match the tanks.
Rayden
'23 Lightning Lariat ER
Definitely the milkcrate idea. I've got a couple of them and that's the only way I carry my propane tanks now. I don't even strap them down. With the spray on bedliner, there's enough friction that they don't move. I've only got a few miles to a Lowe's where I swap them out, so provided I don't do any redlight launching, I'm good. ;)
The standard fwd bed cleats are low enough to strap them in I think.
MachLightning
Eric
2023 Mach E GT, 2022 F-150 Lightning Platinum
Get some ratchet straps and keep em under the rear seats. You'll use them ALL the time when you have them.
